Lc500 convertible trunk inside handle
Old Feb 11, 2026 | 11:55 AM
Bruce128's Avatar
Bruce128
Default Lc500 convertible trunk inside handle
This is probably a stupid question but I can't figure out the handle inside the trunk lid of the LC 500 convertible. I'm new to the car. I really don't want to slam the outside of the trunk but if I close it too gently it doesn't lock. I'm not sure how using a handle inside the truck helps me close the trunk without hitting my hand. Can somebody please enlighten me. What's the best way to close the trunk without slamming it or putting your hands all over the paint
Also. Once the door handles close on their own but the car isn't locked is there any way to lock it without taking the key fob out? Can you lock it from the door handle or trunk button without reopening the door?
Thanks
Old Feb 11, 2026 | 12:20 PM
glennbaz's Avatar
glennbaz
As far as the trunk goes, I've never had a problem pulling the lid closed and slipping my hand out as the lid is closing. It's not very heavy and the pistons are rather weak so you don't have to pull it to fast or hard leaving plenty of time to clear your hand before it fully closes. As far as the door lock goes, once the handle retracts the only way to lock it without the fob or using the phone app is to tap the front of the handle to re-extend it then tap the rear of the handle to fully lock it.
Glenn
Old Feb 11, 2026 | 02:53 PM
ratchettt's Avatar
ratchettt
Inside handle fairly useless but dextrally doable. My method is using the round exterior trunk "L" logo as a touch point to gently clos up.
Old Feb 13, 2026 | 08:24 AM
rmbrewer's Avatar
rmbrewer
I start closing w tje trunk handle and finish by pushing down on the third brake light lens; but then again, I have the convertible, which is just one more reason to get the convertible model, lol.
Rob
Old Feb 13, 2026 | 04:41 PM
Bruce128's Avatar
Bruce128
I also have convertible, that seems good to me
Old Feb 14, 2026 | 03:29 AM
OutlawTita's Avatar
OutlawTita
Rob
exactly how I close my trunk as well
Old Feb 14, 2026 | 03:02 PM
Veight's Avatar
Veight
It becomes second nature to pull the trunk closed from the inside handle. You don’t need to slam it so it’s a quick tug and remove your hand.
Thanks
Old Feb 14, 2026 | 05:15 PM
stockGX11's Avatar
stockGX11
Thanks
The trunk lid shock is a bit stiff at first, it will loosen up over time.
Old Feb 14, 2026 | 06:57 PM
Bruce128's Avatar
Bruce128
Okay that makes sense because my trunk lid is not that easy to close. Momentum doesn't really carry it. I tried that and then I got a message on my phone that the trunk lid was open after I went in the house. So it might look closed but it's not fully latched
EllieJ2323
NX - 1st Gen (2015-2021)
13
Apr 9, 2024 05:54 PM
er34
Aug 14, 2017 06:44 PM
NickTomsyc
Mar 28, 2012 05:13 PM
SilentWish
Aug 27, 2010 11:21 AM
LexusNut13
Jul 12, 2007 01:15 AM
