Diff oil
Old Dec 11, 2017 | 10:49 PM
isfvss's Avatar
isfvss
Default Diff oil
I know what the book recommends but is fully synthetic oil the best for a ISF 2011 DIFF just your thoughts would be appreciated cheers
Old Dec 12, 2017 | 10:06 AM
lorenr's Avatar
lorenr
Synthetic gear oil from any number of reputable manufacturers is an excellent product. I believe (chemist, retired) it is a better product than standard gear oil. In my opinion it does reduce friction because the number of long chain hydrocarbons is much greater.
Because I own so many vehicles and maintain all of them myself, I always use the lubricants that can go a long time between changes. Synthetics fit that requirement even though they are more expensive. I believe Toyota uses synthetic in their differentials to reduce friction which increases durability.
I believe there are only a few refiners that produce synthetic oils and lubricants. A friend of mine works for a Chevron lube plant and they receive it by rail car. I'm not even sure they add much in the way of friction modifiers.
Loren
Old Dec 12, 2017 | 11:14 AM
mikersoft's Avatar
mikersoft
FWIW, I used this when I change my diff oil last spring.
-Mike
Old Dec 12, 2017 | 02:14 PM
Greatest's Avatar
Greatest
So the book calls for 75w 85m, right? But many are using 75w 90. Is it the consensus that this is fine and or better?
Old Dec 12, 2017 | 02:55 PM
SoulFreak's Avatar
SoulFreak
https://www.clublexus.com/forums/is-...rear-diff.html
I used exactly what Mike showed above, Redline and same weight.
Old Dec 12, 2017 | 09:24 PM
clarionguy's Avatar
clarionguy
I used the stock Toyota Diff stuff - came in a steel can.
remember to take the TOP off first - then the bottom drain one - just in case.
In my horrible case I got the top one off and could not get the bottom one off due to corrosion
Old Dec 13, 2017 | 08:18 AM
Greatest's Avatar
Greatest
Now that the Balckstone numbers have been called into question, when are you all changing your ATF? Or did that change anything?
Old Dec 13, 2017 | 10:24 AM
jdmSW20's Avatar
jdmSW20
I got my rear diff oil fluid changed at the dealership so whatever the OEM fluid is, that's what's in mine
skyline03
RX - 3rd Gen (2010-2015)
Feb 5, 2018 12:44 AM
soupyb
IS F (2008-2014)
43
Mar 9, 2016 04:23 PM
Rollaboy
Mar 31, 2013 07:51 AM
tongpoh
May 13, 2010 12:18 PM
itsallgood
Mar 6, 2002 09:03 AM
