Problem with new brake pads, with pic
Old May 6, 2013 | 06:13 PM
mikellucci's Avatar
mikellucci
Default Problem with new brake pads, with pic
Hey guys, anyone know what could cause new front brake pads to wear new rotors this way? The rotors are black zinc plated...the issue is pads only touching the ends (silver rings). The rears are both brand new as well and wearing perfectly. Both my fronts look this way after a few days of driving.
The "grooves" aren't grooves at all...just coloring wear as if the pads are only making contact in those outer areas.
Fyi, I bought front and rear pads long ago can't even remember what brand they are. 90% sure they aren't Wherever's or the ones people had other odd wear issues with.
Edit- it's an is350 with ISF hubs, rotors, calipers and more
Old May 6, 2013 | 08:35 PM
DCoolBeans's Avatar
DCoolBeans
get new brake pads....throw your old ones away
Old May 6, 2013 | 10:25 PM
flowrider's Avatar
flowrider
Veteran: Air Force
I agree. Plus, I see no evidence that you tried to bed the brakes. IMHO, that's an important first step to gain the ultimate brake performance.
Lou
Old May 7, 2013 | 05:52 AM
mikellucci's Avatar
mikellucci
That was after bedding.. If you look at rears they are fine. New pads f/r, strange.. Oh well, ill buy new front pads while it waits at the body shop for clean up
Old May 7, 2013 | 06:33 AM
BS ISF's Avatar
BS ISF
Details please?
Old May 7, 2013 | 06:42 AM
digger08's Avatar
digger08
ISX50 with some sort of conversion and F brakes.....
Digger08
Old May 7, 2013 | 06:43 AM
jkeifer3's Avatar
jkeifer3
Default The rotors could be "misshapen"
The rotors could be ground to a concave (thinner in the middle) profile for whatever reason. Were the rotors new and what was the brand name?
Old May 7, 2013 | 07:55 AM
VtotheJ's Avatar
VtotheJ
This thread doesn't belong in the ISF forums.
Old May 7, 2013 | 09:21 AM
mikellucci's Avatar
mikellucci
Whys that? Its an is350 with ISF hubs, rotors, calipers and more.
Same setup you have; should it be in the hybrid forum?
Talked to brake performance and will be replacing front pads.
Old May 7, 2013 | 06:52 PM
DCoolBeans's Avatar
DCoolBeans
I had the wearevers and had to throw themn in the trash for this same reason. Upgraded to Project Mu's and the problem went AWAY AND BRAKING FELT 100 TIMES BETTER. Get oem or equivilant
ps cool lugs, never seen em like that
Old May 8, 2013 | 10:17 AM
9aristo's Avatar
9aristo
I have never seen that happen ever.
Used pads with new rotors maybe? If you're swapping in new rotors, you should've swapped in new pads too.
jdm_altzza
IS F (2008-2014)
19
Jun 30, 2016 08:07 PM
hybridanim
Suspension and Brakes
Apr 5, 2011 05:22 PM
smokyis350
Mar 16, 2010 03:51 AM
LexLS
Maintenance
Oct 23, 2003 12:46 PM
sxys_sc4
Oct 12, 2002 02:01 AM
