IS 500 - CEL problem and update
Old Dec 7, 2022 | 07:57 AM
  #631
wthrman2's Avatar
wthrman2
^^ For what it's worth, I don't think I have seen a 2023 have the CEL problem so far. I still think the 2022s that had the problem were associated with a bad batch of gaskets and depending who got them or not. So far, and knock on wood, I have not had a single issue with mine. This is an amazing car and if you have any thoughts of getting one, don't miss your chance.
Old Dec 7, 2022 | 10:27 AM
  #632
StillSo42's Avatar
StillSo42
same here wthrman2, no problem as of yet for my 22....crossing fingers
Old Dec 7, 2022 | 10:34 AM
  #633
DLPTony's Avatar
DLPTony
Amen! No issues thus far. 🙏🏾
Old Dec 7, 2022 | 12:08 PM
  #634
95bat's Avatar
95bat
Ditto, I am coming up on 1 year of ownership, a little over 4k miles, and no CEL. If it does come up I will get it fixed and keep enjoying my USBeautiful car!
Old Dec 8, 2022 | 11:37 AM
  #635
drawg22's Avatar
drawg22
No issues on the CEL for mine. Only issues to date is where the A-Pillar interior cover came lose at the top and I'm getting that replaced tomorrow.
Old Dec 12, 2022 | 02:33 PM
  #636
DaOne's Avatar
DaOne
So, my dealer told me that my IS 500 already had the cel issue fixed and the codes were caused by my aftermarket intake. However, I have been running the aftermarket intake for about 1000 plus miles before the issue occurred. When I get it back on Wednesday, I’ll continue to run it without the intake to see if the issues return.
Old Dec 12, 2022 | 02:37 PM
  #637
95bat's Avatar
95bat
Did they remove your intake? I think they're wrong, if it's the same codes at least. Intakes can cause other CEL issues though.
Old Dec 12, 2022 | 04:33 PM
  #638
CyberNinja's Avatar
CyberNinja
I think it’s because your aftermarket intake allows for more air into the engine, so that would mean that you have to adjust and remap your ecu tuning so that the air/fuel ratio is correct, thus tripping your CEL. If this is the issue, you’ll probably notice that over the next couple thousand miles, you’ll use up more fuel and/or make less power because the ecu is assuming the old oem intake is on there and it has account for that. So without a way to tune the ecu yet, I would stick to stock until then. It does take several hundred miles more or less to trigger a CEL for something like this though.
Old Dec 12, 2022 | 06:01 PM
  #639
DaOne's Avatar
DaOne
I can see the logic, but it took me over 1000 miles to trigger the cel issue.
Old Dec 13, 2022 | 05:33 AM
  #640
jororo's Avatar
jororo
Are they telling you which sensor is throwing the code? If it’s the o2 sensor downstream of the exhaust gasket then the gasket is the issue.
Might have them actually check the alignment of the exhaust system where it meets the troublesome gasket. On my ‘22, they first replaced each bank’s o2 sensors, the CEL came back each time and they then replaced the gaskets. CEL came back yet again at which point Lexus flew someone in to look it over, and he realized that the exhaust system wasn’t aligned properly. The gaskets being the weakest link were therefore were taking the sacrificial brunt of that misalignment. Sounds like they used some brute force to make things properly flush at the gaskets but realigning the exhaust system seemed to end the problem.
Maybe yours has the same exhaust misalignment issue? If so it’ll keep blowing gaskets until the root cause is fixed.
Old Sep 29, 2024 | 01:45 PM
  #641
omgandy's Avatar
omgandy
10th Gear
I just got the CEL on my ‘23. Will be taking it in this week
Old Sep 29, 2024 | 03:04 PM
  #642
TGPCanada's Avatar
TGPCanada
How much mileage so far?
Old Sep 29, 2024 | 06:30 PM
  #643
omgandy's Avatar
omgandy
10th Gear
Happened at 9,607
Old Sep 30, 2024 | 07:25 AM
  #644
arentz07's Avatar
arentz07
Happened at 9,607
Hmm, could it be the same issue I had? My throttle body needed to be replaced. If you have code P2111, it may be the same issue.
https://www.clublexus.com/forums/is-...dtc-p2111.html
Old Sep 30, 2024 | 03:02 PM
  #645
omgandy's Avatar
omgandy
10th Gear
I was getting P0505. I got gas yesterday and the code turned off. I’m probably going to take it if the code shows up again
