IS 500 - CEL problem and update
Old Dec 13, 2022 | 05:33 AM
  #646
jororo's Avatar
jororo
Originally Posted by DaOne
I can see the logic, but it took me over 1000 miles to trigger the cel issue.
Are they telling you which sensor is throwing the code? If it’s the o2 sensor downstream of the exhaust gasket then the gasket is the issue.
Might have them actually check the alignment of the exhaust system where it meets the troublesome gasket. On my ‘22, they first replaced each bank’s o2 sensors, the CEL came back each time and they then replaced the gaskets. CEL came back yet again at which point Lexus flew someone in to look it over, and he realized that the exhaust system wasn’t aligned properly. The gaskets being the weakest link were therefore were taking the sacrificial brunt of that misalignment. Sounds like they used some brute force to make things properly flush at the gaskets but realigning the exhaust system seemed to end the problem.
Maybe yours has the same exhaust misalignment issue? If so it’ll keep blowing gaskets until the root cause is fixed.
Old Sep 29, 2024 | 01:45 PM
  #647
omgandy's Avatar
omgandy
10th Gear
I just got the CEL on my ‘23. Will be taking it in this week
Old Sep 29, 2024 | 03:04 PM
  #648
TGPCanada's Avatar
TGPCanada
How much mileage so far?
Old Sep 29, 2024 | 06:30 PM
  #649
omgandy's Avatar
omgandy
10th Gear
Happened at 9,607
Old Sep 30, 2024 | 07:25 AM
  #650
arentz07's Avatar
arentz07
Happened at 9,607
Hmm, could it be the same issue I had? My throttle body needed to be replaced. If you have code P2111, it may be the same issue.
https://www.clublexus.com/forums/is-...dtc-p2111.html
Old Sep 30, 2024 | 03:02 PM
  #651
omgandy's Avatar
omgandy
10th Gear
I was getting P0505. I got gas yesterday and the code turned off. I’m probably going to take it if the code shows up again
Old Dec 10, 2024 | 05:07 AM
  #652
Kanpai's Avatar
Kanpai
Started up today to head into work and got the CEL for parking brake malfunction. Need to go in for my service anyways, but this is still a pain in the ***. Just about to hit 15k miles too
Old Dec 10, 2024 | 10:21 AM
  #653
arentz07's Avatar
arentz07
If you're curious, you could get the codes read. I had P2111 at about 13k miles. It ended up being a bad throttle body.
Old Dec 10, 2024 | 12:38 PM
  #654
snowyblue's Avatar
snowyblue
@Kanpai i had the same code as @arentz07 and ended up just unplugging throttle body and cleaning throttle body. code never came back after 3 months. worth a shot if your in a pinch or cant get to the dealer asap. i would still go to get it replaced if under warranty
Old Dec 10, 2024 | 02:01 PM
  #655
Kanpai's Avatar
Kanpai
Between my work schedule and life getting in the way, I'm just going to have to end up taking it in to the dealer Thursday.
Old Dec 12, 2024 | 07:49 AM
  #656
Muinarc's Avatar
Muinarc
I got this code last month and unfortunately for me a rodent had chewed through the cam position sensor wiring right at the connector on the valve cover. It seems that parking brake code is a catch-all for everything.
Old Dec 12, 2024 | 03:04 PM
  #657
Kanpai's Avatar
Kanpai
Turns out, I had the same issue! Dealership fixed it free of charge
Old Dec 13, 2024 | 05:32 AM
  #658
cajun's Avatar
cajun
Originally Posted by cajun
Sooooo, guess it's my turn...Ugh! Thought I got a Check Engine Light pass when I made it to 10,000 miles with no issues. I informed the service department that this is likely a gasket issue, buuuuut they claimed they can only act on the results of the system scan which is as follows:
"Checked for codes and found P013A. Oxygen Sensor slow response rich to lean bank 1 sensor 2. No TSB for this code at this time. Cleared codes. Checked for exhaust leak. No leak found at this time. Road test vehicle. Could not duplicate issue. 02 sensors are in range. Monitors passed. Need to create TAS case and check vehicle again. Customer did not want to leave vehicle at this time. Will reschedule for diagnosis."
No Toyota Service Bulletin was surprising given this is clearly an issue with this model. At any rate, it's cleared for now, but I suspect I will need to return to the service center in the near future as the Check Engine Light may very well return. Will keep you posted...
UPDATE: Two years later, the issue has (thankfully) not recurred.
Old Dec 13, 2024 | 07:30 AM
  #659
Muinarc's Avatar
Muinarc
Unhappy
Wow nice, it cost me $500
Old Dec 13, 2024 | 08:04 AM
  #660
Kanpai's Avatar
Kanpai
Sorry to hear. Dealers suck and we're better off without them
