Maintenance required light won’t go off
Old Sep 4, 2019 | 06:13 AM
cm6063's Avatar
cm6063
Default Maintenance required light won’t go off
So I just did my regular oil change, and I reset the intervals in the infotainment system. However, I just got a maintenance required light that won’t go off. There is nothing wrong with the car, and there is no maintenance to perform. I did just pass the 55,000 mile mark, but how do I get rid of this light? 2015 IS 350 AWD base.
Old Sep 4, 2019 | 07:17 AM
Tlam94's Avatar
Tlam94
try disconnecting the negative and wait a few minutes.
it could reset the ecu and if its not a real problem it would go away.
Rh209216's Avatar
Rh209216
The reset is in your settings on the speedometer. Use the steering wheel controls to access it. The maintenance required in the infotainment system has its separate reset which is probably the one you did.
Old Sep 4, 2019 | 08:07 AM
arentz07's Avatar
arentz07
+1, dealer forgot to reset mine last time I took it in. So, I did it myself.
Old Sep 4, 2019 | 03:29 PM
Flash5's Avatar
Flash5
I have 2 resets, the oil change reset and the regular maintenance reset. Maybe you only reset one of them.
Old Sep 4, 2019 | 05:34 PM
cm6063's Avatar
cm6063
Figured it out. Made a video, too.
Kareil971
GX - 1st Gen (2003-2009)
Nov 1, 2018 05:05 PM
SRTISF
RC F (2015-present)
Sep 19, 2017 01:10 AM
FrOHiKE
Feb 23, 2016 05:55 PM
igo2xses
Oct 16, 2008 11:47 PM
250-awd
Aug 30, 2007 02:53 PM
