Air filter(s) replacement
Old Nov 3, 2015 | 12:48 PM
doodlebug's Avatar
doodlebug
Default Air filter(s) replacement
What are you guys using when you change your air and cabin filters?
Are you using OEM or parts store filters?
Old Nov 3, 2015 | 12:52 PM
Imprezario's Avatar
Imprezario
OEM cabin filters only and long-lasting TOM's air filter.
Old Nov 3, 2015 | 01:05 PM
cp2's Avatar
cp2
Veteran: Air Force
I'm using the f sport filter for the motor. get the cabin filter from Toyota dealer...usually cheaper.
Old Nov 3, 2015 | 02:21 PM
3ISRC's Avatar
3ISRC
F-Sport air filter. Way better than stock.
Old Nov 3, 2015 | 02:55 PM
simon3huna's Avatar
simon3huna
For the guys with aftermarket engine air filters.. How often do you change/clean the air filter? whats the best way to clean it? i got the aFe Magnum force Stage-2 Pro 5R.
Old Nov 3, 2015 | 03:04 PM
Imprezario's Avatar
Imprezario
No tricks here - just blow the dust away with the air blower. Do it after 10000 km of driving.
Old Nov 3, 2015 | 04:13 PM
theoryguy's Avatar
theoryguy
Got a regular K&N filter, no problems thus far.
Old Nov 3, 2015 | 04:14 PM
theoryguy's Avatar
theoryguy
I went to 4 Toyota dealers and none had the cabin filter. I ended up buying it on Amazon.
Old Nov 3, 2015 | 04:35 PM
doodlebug's Avatar
doodlebug
What part number for the cabin filter are you buying?
Old Nov 3, 2015 | 05:41 PM
Barnesie's Avatar
Barnesie
Do you happen to have the part number for the f sport air filter? Thanks!
Old Nov 3, 2015 | 07:12 PM
Daniel2311's Avatar
Daniel2311
PTR03-53141-AA, will fit directly into IS350 non F sport. I did the upgrade 6 months ago, very easy to install.
Save your stock air filter, the F sport filter can be washed, you can use your stock filter for a day or two while you allow the F sport filter to dry.
Dan
Old Nov 4, 2015 | 07:30 AM
cp2's Avatar
cp2
Veteran: Air Force
just to clarify, that part number fits both f sport and non f sport stock intake boxes.
Old Nov 4, 2015 | 07:32 AM
cp2's Avatar
cp2
Veteran: Air Force
Originally Posted by doodlebug
what part number for the cabin filter are you buying?
8713930100
Old Nov 4, 2015 | 08:11 AM
doodlebug's Avatar
doodlebug
8713930100
Thank you, CP2.
Old Nov 4, 2015 | 08:14 AM
Baopee's Avatar
Baopee
I clean my K&N every 10k.
