Idle surging when cold
Old Nov 26, 2013 | 11:33 AM
JLex23's Avatar
JLex23
Default Idle surging when cold
Now that it's getting colder in the Midwest have any of you experienced your idle bouncing on cold starts for the IS250? It does not do it immediately when you start the car but after 2-3 minutes the idle will actually go up just slightly and bounce up and down within a range of about 100 RPMS. Car drives fine and as it warms up the behavior subsides...any thoughts on this??
Old Nov 26, 2013 | 12:38 PM
liqinwei26's Avatar
liqinwei26
I get the same thing here in WI. But once your temperature is up, then it will drop
Old Nov 26, 2013 | 01:26 PM
KumaF's Avatar
KumaF
I think this is quite common as my BMW does it too.
Old Nov 26, 2013 | 01:29 PM
semoquer's Avatar
semoquer
yep.. sounds pretty normal. cold weather hit NYC and my Acura has the same idle characteristics you're writing about.
Old Nov 26, 2013 | 01:34 PM
JLex23's Avatar
JLex23
I just thought it was odd...we have had quite a few cold days and some days the idle will actually go up and start bouncing for awhile before it begins to go down and some days it will start high and lower as it should once the car begins to warm up...maybe I should just move to a warmer climate
Old Nov 26, 2013 | 01:47 PM
Newpatriot's Avatar
Newpatriot
it's - 22 degrees up here in Canada. rpm jumps usually for a minute or so. once car starting to warm engine is fine. it usually happen once in awhile if temperature drops. also notice digital gauge slow to response on start up.
Old Nov 26, 2013 | 01:51 PM
JLex23's Avatar
JLex23
Glad to hear that I'm not the only one...negative 22 is no joke!!!
Old Nov 26, 2013 | 03:47 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Test the effects of having your HVAC on and off. I noticed when on, RPMs go up about 100 whether the AC is on or not. I only turn it on when the engine is at least a quarter warmed up.
xCWolf
Sep 2, 2018 08:26 AM
bigblack06
Jul 6, 2016 08:57 AM
fgerwe
Dec 2, 2007 09:17 PM
sc4canada
Oct 9, 2003 05:50 AM
749009
Nov 9, 2001 12:35 PM
