RES ECU/Remote Start
Seeing how I park my car outside, this would be awesome to have during those cold seasons instead getting my water hose in freezing temps during winter time.
I've confirmed with the parts and services department in person and the total cost is as follows;
Lexus Parts and Services
300 Martin Ave Santa Clara, CA 95050
(866) 208-2871
The part(s) can be purchased through the dealer or online.
They welcome either method you prefer.
http://is.sewellparts.com/accessorie...2014/6362.html
RES ECU - $399/$293
Labor 3 Hours - $387.24
Warranty - 1 Year, date of installation
My question is;
1. Is this supported by smartphones, similar to the RX series?
2. Has anyone done this yet?
3. Anyone plan on doing this anytime in the near future?
4. How does remote start work, does your engine stay on, or do you need to manually start it?
5. Can you customize how your climate works or is it preset with your car basically turning on but no movement?
In the IS Accessories catalog, it's has a brief description but not a whole lot of information anywhere else.
2. I had it on my 13 GS and it works good
3. I dunno
4. with the doors locked you hit the lock button 3 times in a row and the hold it the third time and the car will start. the car will run for a max of 10 min and then turn off or you can turn it off using your key fob. the car will however turn off when you walk up to it and its still running and open the door.
5. the climate works basically with how ever you last left the car. So if your car is under the sun all day make sure to leave it on auto LOW and it will start with that setting when you remote start the car.
3. I dunno
My guess is that it turns on using the battery only, while not even initiating the ignition.
That's why it only stays on for 10 mins, any more than that, it'll kill the battery.
From the looks of the PDF installation procedure, it seems accurrate.
For $800, I'm not sure if this is worth the investment.
Maybe I'll just stick to the water house in the morning.
I'll wait for others to do this before I pursue.
Thanks!
I'm sure the distance is very far, dependent on the signal of your FOB/Token.
Or do what I do, put your token under your chin, then press the unlock button.
Gives it at least another 10-20 feet because your head acts as an antenna.
Be warned, I hear it kills 100,000 brain cells each time you do that. Not confirmed lol.
I'd have to get mine aftermarket since it was never installed or available when I picked up my car.
I also fear that they may have an updated version of RES to RES+ and would shoot myself in the foot if they do that somewhere in the near future.
That taps into the car's system, man I've always wanted that remote start and control climate and stuff. Any idea on the cost of it all?
With an upgrade on the audio system, and remote start, the car is such a money pit!
You can find out more about Viper on:
http://www.viper.com/SmartStart/Modules.aspx
Is it true you have to pay a $50 monthly/annual service no matter which one you get?
If possible, please provide link to thread or bump it
Thanks!
Thanks!
https://www.clublexus.com/forums/is-...rt-anyone.html
