Best thing is have a good insurance policy. If they want your car, they will get your car. Even if you deter them the end result will likely just being tons of damage since you're already dealing with upstanding people.
Hide some airtags/smart tags in the car.
thanks for help
I kind of want just want another layer of security to make it harder , if my car gets stolen i dont want it back haha
Just wanted to see if wiring was right so I didn't cause issues without cutting factory wiring
Also wiring the negative and positive wires like this is correct?
There’s no positive and negative here, just a path for current to pass through (to the circuit it looks like a wire).
If the left most fuse contacts (in the picture) are both connected to the left tap tab, and right most fuse contacts are not connected together internally, and the right most bottom fuse contact is connected to the right most tap tab, you should be good to go. Use an ohm meter to verify the internal connections of the tap.
Ok cool
So pretty much how it is in the picture will work fine
My diagram is was just gonna add another 20amp fuse in the circuit for safety
