Eeprom dump from Fsport instrument cluster w/o PCS
Does anyone have an eeprom dump of an f sport cluster without PCS? It is a rare find, as PCS comes standard in many markets after 2017, but not in all.
Years sought - 2018, 2019, 2020.
I have a dump from a 2018 Canadian cluster. Didn't try it yet, so not sure which features that car had. If anyone needs it - let me know.
Thanks a ton for the file! I'm only getting back to the project after the holidays and knowing I wont need to drive the car at the moment. Is your car with or without PCS/RADAR?
Ive got a dump file from my cluster now. Attached it is if anyone wants a to see. Ill most likely make a new thread with the project to document it properly.
Cheers,
Paul
Cheers,
Paul
Ian
Here's what happened:
It was in KM at 126641km
It gave me the following errors:
VGRS
LDA
PCS
DRS
Also MPG units disappeared and could only switch between
KM/L and L/100KM
I was then able to re-flash with my dump and went back to as it was, with just the PCS error present
Wait what is your car? I assume 300h? Does it have any of the other systems? It might be coded differently between 2013 and 2015. Ive managed to get a dump from another 300h posted in 2016 in miles as well and will try that file tonight. There are a few differences from what I can see initially.
Thanks
Paul
VGRS
LDA
PCS
DRS
KM/L and L/100KM
Thanks
Paul
Mine in UK Lexus is300h 2014. The odo certainly is in Miles and not KM on mine with that file. Not sure what is going on with your go make it come up as KM.
As I have said my UK car spec and model - for clarity what's yours
Just for more context we had 3 tiers to choose from in RSA. t:
E - Base
EX - Lux in other markets added Auto wipers, nav, remotetouch, AutoRearMirror (My Car)
F-Sport - that had VGRS and AVS.
You could only choose exterior and interior colours as options not equipment as with all Toyota/Lexus products still here, not sure how it works in different regions.
The cluster I got is from a 2013 IS250 from Poland.
There must be somewhere else data is stored to come up as KM and not even the correct mileage to what the file is named. The mileage calculations also end up at 128681km from your dump now that I calculate it.
But it still doesn't make sense since, to correct the mileage on other f-sport clusters in miles you have to convert to miles from km. And yours would have been 175864KM converted.
The model number of the Cluster:
83800-53F80-G
I was originally looking to buy a cluster from the UK with the exact same part number but just in miles as it was a bit cheaper, decided against it. So it surprises me that it stays in KM.
There is also a listing on Ebay for the same model cluster in Canada
E - Base
83800-53F80-G
Regards
