EEPROM on 2016 FSport Cluster
Old May 2, 2025 | 05:01 AM
james250's Avatar
james250
Default EEPROM on 2016 FSport Cluster
Does anyone know where the EEPROM chip on the 2016 fsport cluster is located and what model the eeprom chip is?
Old May 3, 2025 | 02:17 AM
Ditto21's Avatar
Ditto21
10th Gear
It's located within the cluster on the main PCB. From memory it's a microchip 93C66
Old May 3, 2025 | 07:21 AM
james250's Avatar
james250
theres an opening for the rear of the cluster but couldn’t see the PCB there. So does cluster need to be dismantled from the front to gain access to it? On the rear there’s a lot of the servos and cogs related to the moving panel
Old May 3, 2025 | 08:48 AM
Ditto21's Avatar
Ditto21
10th Gear
Yes it most definitely needs the clock removing from the car and dismantling. Not for the faint hearted. The pcb is inside the unit and almost as big as the unit itself. The Eeprom your looking for is on it.
Why do you need to access the Eeprom??
bunty95
RX - 4th Gen (2016-2022)
Oct 11, 2025 07:26 AM
Iampaower
Apr 18, 2022 02:36 PM
Jaypmanuel
Jun 23, 2021 05:11 AM
luuser75
Dec 1, 2017 03:01 PM
