TPMS Sensor serial numbers keep getting lost by Body Control Module
Old Jul 26, 2022 | 01:41 PM
delpaso's Avatar
delpaso
Default [SOLVED] TPMS Sensor serial numbers keep getting lost by Body Control Module
2007 IS350
I got all four TPMS sensors replaced about a year ago, and having an issue recently whereby I'm getting a check system light and tire pressure light come on at the same time.
I've taken it to my Lexus specialist and he says that all four serial codes are disappearing from the Body Control Module at the same time.
Has anyone else had this issue?
Old Jul 27, 2022 | 08:39 AM
MikeFig82's Avatar
MikeFig82
Originally Posted by delpaso
2007 IS350
Has anyone cycled through the TPMS switch settings? On the left of the steering wheel. Meaning you have primary set, and secondary set.
If done mostly they're saved on the primary set. If you switch to secondary there is nothing stored there. Just something to be aware of.
Old Jul 27, 2022 | 08:42 AM
delpaso's Avatar
delpaso
Yep, unfortunately not the easy fix I'd hoped for when I realized it stores two sets of tires!
Old Jul 27, 2022 | 08:46 AM
MikeFig82's Avatar
MikeFig82
What brand are the sensors?
Old Jul 27, 2022 | 08:55 AM
delpaso's Avatar
delpaso
They're OEM
Old Jul 27, 2022 | 09:14 AM
MikeFig82's Avatar
MikeFig82
They're OEM
So I'm assuming they programmed the sensor's to Main, and 2nd?
If so I would try to initialize both sets with correct tire pressure in the morning. Inflate all tires to door jam pressure specs. Then initialize both sets to the pressure. Then just set back to main if the light clears. Again I'm assuming the codes get lost because of the system check light maybe. Don't try to set pressure in hot temps it needs to be set in the morning while sitting over night. Preferably in around at a 70 temp should be good.
There is a ton of threads on TPMS. Nothing seems to point to your particular case.
Old Jul 27, 2022 | 09:35 AM
delpaso's Avatar
delpaso
I think they would've just programmed to main but good question.
I'll give the initializing a shot and report back. Thanks for your responses, much appreciated!
Old Jul 28, 2022 | 04:28 PM
lexo98's Avatar
lexo98
Not saying that it’s for sure your issue but for whatever reason on Toyota/ Lexus we have had random issues where the initialization of new sensors doesn’t take. Immediately After the sensors have been programmed into the ECU without turning the car off all 4 sensors need to be rescanned so they send a signal to the ECU. Not saying this is your issue but worth a try.
Old Jul 28, 2022 | 05:48 PM
2013FSport's Avatar
2013FSport
Techstream shows this data.
App OBD Fusion with the Lexus PID pack does not atm support reading pressure data or sensor ID. Other handheld tools may work, but IDK.
Old Jul 28, 2022 | 06:04 PM
delpaso's Avatar
delpaso
Thank you, I'll give this a shot and see if it works!
Old Aug 11, 2022 | 07:10 PM
delpaso's Avatar
delpaso
Default Solved
We have a solution!
As per response from @lexo98 above:
Immediately after the sensors have been programmed into the ECU without turning the car off all 4 sensors need to be rescanned so they send a signal to the ECU.
This clears the check system warning for good.
Previously, just reprogramming the sensor IDs would clear the check system warning but it would inevitably come back within 24hrs or around 35-40 miles. Have now driven a couple hundred miles and it's been about 10 days and still all clear.
FatBuoy
Jul 24, 2022 04:24 AM
Kingtut89
Jul 16, 2021 08:03 AM
pauljcl
Dec 23, 2015 08:09 AM
freeflight
Jun 7, 2015 09:39 PM
ByoungWoo
Aug 27, 2008 03:09 PM
