Corroded Side Mirrors Pushing Out & Cracking Plastic Housing
Old Apr 14, 2020 | 05:06 PM
valeoray's Avatar
valeoray
Default Corroded Side Mirrors Pushing & Cracking Plastic Housing (Added Soundproofing Doors!)
I had to cut off the front piece to modify the bottom part so that the metal can stick out without pushing the housing. I will use black silicone to fill in the gap.
The drivers side base is also cracking, probably due to corrosion. I had greasy fluid coming out of the mirrors staining the doors for a few years.
Anyone know where to get cheap mirror assemblies?
The metal base inside is cracked and has pushed out the plastic causing it to crack.
Corroded metal is split. Mirror is still sturdy and not loose.
After cutting out the bottom part of the housing near the front.
Last edited by valeoray; May 17, 2020 at 10:59 AM. Reason: Added link showing replacement and soundproofing
Old Apr 15, 2020 | 07:52 AM
sinister2c's Avatar
sinister2c
upgrade to newer model years with signals. just got to run a single wire to turn signals and probably cut and rewire the harness (different plugs) for the motors.
aftermarket set is like $170 on ebay, just need to get them painted.
https://www.ebay.com/itm/Power-Mirror-Set-For-2010-2015-Lexus-IS250-Heated-With-Signal-Light-Puddle-Light/352802004106
OEM used is like $200 each.
https://www.ebay.com/itm/2010-2015-LEXUS-IS250C-IS350C-CONVERTIBLE-FRONT-LEFT-DRIVER-MIRROR-OEM-BLACK/153366023082
Old Apr 15, 2020 | 08:11 AM
valeoray's Avatar
valeoray
Thanks. Mine already have signals.
I'm in Canada. Looks like the exchange rate is pretty bad right now at $1USD = $1.41CAD.
Old Apr 15, 2020 | 07:08 PM
BabyGate's Avatar
BabyGate
Try source an used one on ebay uk. Search for "lexus is 220 250 wing mirror". You could probably find one in decent shape for around $100-150 Canadian, with power folding as a bonus. ;-).
Old Apr 16, 2020 | 01:02 PM
valeoray's Avatar
valeoray
Thanks but a lot of them do not have the signal indicator. Ones that do are expensive.
Anyhow, here is the mirror after the silicone job. Note the mirror is in the folded position in case you're wondering why it looks weird with respect to the base.
Old Apr 17, 2020 | 07:41 AM
valeoray's Avatar
valeoray
Is this a common problem with our cars?
Does anyone else have/had this problem?
Old Apr 17, 2020 | 09:55 AM
Gville350's Avatar
Gville350
I've never actually seen that before on CL here.
Old Apr 17, 2020 | 10:28 AM
72gs455's Avatar
72gs455
I have the hard water marks on mine, It was that way when I bought it in January.
Once the weather gets better i'm gonna clean it up. I don't think i have that bad of corrosion inside but who knows...
Old Apr 19, 2020 | 11:06 AM
valeoray's Avatar
valeoray
Did anyone buy from www.dcretiv.com before?
I did a search on the domain name and it comes up as being in Texas.
The site looks shady though.
Old May 17, 2020 | 10:57 AM
valeoray's Avatar
valeoray
Hey everyone, I replaced the side mirrors with aftermarket ones and I soundproofed the doors at the same time.
Old Jan 13, 2021 | 01:28 PM
Captaine's Avatar
Captaine
Samething hapenned here in Quebec...
My right mirror internal structure is completely corroded and fell apart on the road. And the left one is better but many of the structure is gone.
I bought a new OEM one and Toyota corrected the problem by painting the inner structure!
I'm currently trying to find a left OEM mirror with a painted structure. (not easy!)
Right mirror
Left mirror
Right mirror new
Old Jan 17, 2021 | 08:09 AM
Jeeves250's Avatar
Jeeves250
How's ordering from UK ebay? I'm thinking of ordering some things on there for my car, but I am wary of ebay in general.
Old Jan 17, 2021 | 09:05 AM
valeoray's Avatar
valeoray
Captaine,
How much was the OEM mirror?
If you bought the right one from the dealer, why not buy the left from them?
Old Jan 18, 2021 | 08:03 PM
Captaine's Avatar
Captaine
Captaine,
At the dealer the price tag is over 600CAD for a silver one.
I found it on ebay. Came from North Carolina and cost me about 300CAD at my door.
The challenge is that I have the Luxury package on my IS so I need a unit with all the options (heat, auto-dim, memory) and they are very rare. Over that, I want a painted structure unit instead of a bare aluminium one that come from a crashed car...
Well, if you don't have the Luxury pack on your IS, the mirror is a lot cheaper. You can check at www.lexuspartsdirect.ca. They have decent prices. I bought a lot of parts from them.
Old Jan 18, 2021 | 11:49 PM
valeoray's Avatar
valeoray
I got my mirrors from the states and got a cross border company to bring them over the border.
I got one mirror from Auto and Art, and one from CarParts.com. I don't know if they have the luxury pack or if they have a painted structure.
Can also check 1A Auto.
XxGoKoUxX
Nov 3, 2019 08:42 PM
captainva
Dec 3, 2018 08:51 AM
3UZFTE
Nov 4, 2017 08:12 AM
LUX2006
Aug 5, 2017 07:10 PM
Black_SC
Feb 24, 2007 10:47 AM
