ML IS350 sub replacement
Old Oct 15, 2017 | 08:32 AM
coldone's Avatar
coldone
Default ML IS350 sub replacement
Anyone try this
Amazon Amazon
db840DVC
Wired as 8 ohm (series) to replace the ML subwoofer 86160-0WD80? I have seen older LS threads mention this, but wanted to know if anyone did this for 2006-2009 IS250/350?
Old Oct 16, 2017 | 05:05 AM
HankMoody's Avatar
HankMoody
That's not gonna fit it would take a shallow mount sub. Do a search there are a few other threads about replacing it with aftermarket.
Old Oct 16, 2017 | 06:42 AM
coldone's Avatar
coldone
I have exhausted my search to find the right thread. Can u please give link to 06 IS350 ML sub aftermarket, I cant find it 😩
Thanks
Old Oct 16, 2017 | 07:30 AM
coldone's Avatar
coldone
https://www.bestbuy.com/site/maxxsonics-mb-quart-discus-8-dual-voice-coil-8-ohm-subwoofer-gray/9076303.p?skuId=9076303
Old Oct 16, 2017 | 11:47 AM
08treefidd's Avatar
08treefidd
I just did similar research and due to space limitations and the style of that sub, I did a whole different route.
Spent about $1000 total for a single 10, box, 680 RMS watt amp and DM-810 sound processor. My system sounds AMAZING now, so clean and balanced, where before the ML system reminded me of a muffled surround sound system lacking full range sound for music. It has bass now, clarty, and VOLUME. I used ~8 sq ft of Second Skin sound deadening (great stuff) I had left over to do some additional sound deadening. Not a single rattle or squeak in the whole car, so if any of that is suitable for your needs, I did it and was amazed how well it turned out without being invasive and altering a bunch of other things.
Food for thought, probably not an option for everyone but you sound frustrated trying to do an OEM upgrade.
Old Oct 17, 2017 | 05:01 AM
HankMoody's Avatar
HankMoody
spoon fed to you .. https://www.clublexus.com/forums/is-...tml?styleid=15
Old Oct 17, 2017 | 05:13 PM
coldone's Avatar
coldone
Ordered polk audio 8" (8 ohm capable)
Pulled up hard on top rear panel (screwdriver/pry) and pops right up, didnt have to remove back anything, just headrests... 4 10mm screws holding in woofer and wallah.
it DOES sit an inch too high rear mounted, face down for now, but hey its a start, and w headrests Back in, you dont see the slight cover ~
Going to get double sided weather stripping to put between bottom facing speaker and trunk metal, and figure way to fasten speaker down.
Things will change, just a start to replace fully blown stock.
Old Oct 18, 2017 | 05:15 AM
HankMoody's Avatar
HankMoody
This is the one I was looking at.
https://www.crutchfield.com/p_130TSS...-SW2002D2.html (only a 2-5/8 mounting depth)
Old Oct 18, 2017 | 05:25 AM
coldone's Avatar
coldone
Looks nice, but the dual 2 ohm will only get you down to 4 ohms.
Isnt stock sub 8 ohm, and people have problems damaging the ML amp driving to drive down to 4 ohms?
Saf1993
May 16, 2019 10:20 PM
thederke
Nov 30, 2017 12:26 PM
jre002
Nov 13, 2012 01:09 PM
muf-dvr
Feb 20, 2012 06:36 AM
ttiangco
Jun 18, 2011 04:03 PM
