side-mirrors tilt programmable?
Old Apr 29, 2011 | 02:56 AM
rexel77's Avatar
rexel77
Default side-mirrors tilt programmable?
I have a 2008 IS250 - fully loaded. Im wondering if there is a way to program the angle of tilt on the side mirrors when I reverse? Basically, I'd like to be able to see the ground and when it tilts it is not quite where I need it to be. I can manually adjust the mirror once it tilts, but it always goes back to the original spot the next time. Is this possible?
Old Apr 29, 2011 | 10:41 AM
Pnthrzrule's Avatar
Pnthrzrule
I believe the only way you will get the desired result (having a view of the ground in reverse) is to adjust the "home" position down a little more so that when you hit reverse the mirrors tilt down even more.
Old Apr 29, 2011 | 12:20 PM
diablo1714's Avatar
diablo1714
on my '11, the auto-tilt in reverse feature only works when the mirror switch is NOT in neutral (neutral meaning set between the L and R).
It has to be set to either L or R for the auto-tilt to function. Hope this helps on your '08.
edit: oops, I mis-read the question....I don't know how to control/set the final position of the auto-tilt in reverse
Old Apr 29, 2011 | 01:19 PM
BLexodus's Avatar
BLexodus
I dont like the auto-tilt because ot points too much at the ground and I can see like I'm used to in other cars.
Only has my 06 IS350 a few weeks... I need to read the owners manual to see if I can stop it.
Old Apr 29, 2011 | 03:18 PM
anthrax144's Avatar
anthrax144
You can stop it. Put the mirror select switch in between (neither L or R) and the mirrors won't turn down.
And I love the turn-down feature! Between the back-up camera and the mirrors, I can easily back into any space (or out for that matter...)
Old Apr 29, 2011 | 03:26 PM
BLexodus's Avatar
BLexodus
Thanks... I am just so used to my mirrors staying put that I dont know how to back up when the mirrors point to the ground - I want to see the back of the car.
Old Apr 29, 2011 | 03:33 PM
allst4r's Avatar
allst4r
if you buy the side mirrors with the auto tilt function would that add the tilt funct to my non tilting side mirrors? once i replace them of course?
sewell sells them here
http://is.sewellparts.com/accessorie...2007/2399.html
Old Apr 29, 2011 | 03:58 PM
humblehype's Avatar
humblehype
Do some of the IS250 have this feature?
Old Apr 29, 2011 | 06:22 PM
Kurtz's Avatar
Kurtz
Any 2IS with the sport (not F-sport) package or the Luxury package will have this feature. Otherwise it won't.
Old Apr 29, 2011 | 06:23 PM
diablo1714's Avatar
diablo1714
I don't know. There would have to be some way to send a signal to the mirror when the car is put in reverse. so it could require another wire to accomplish this.
Old Apr 29, 2011 | 07:53 PM
humblehype's Avatar
humblehype
OK thanks.
beer88
RX - 4th Gen (2016-2022)
Dec 21, 2016 10:42 AM
DP03
Oct 18, 2016 05:03 PM
triplecore
RX - 3rd Gen (2010-2015)
Sep 6, 2012 10:00 AM
camillian
Jun 26, 2006 08:31 PM
