Question about HID installing
Old Jan 4, 2011 | 05:17 PM
IS250TW's Avatar
IS250TW
CL Folding 25,000
Default Question about HID installing
I just got the Volt HID kit and from some search i found out that the + - are reversed
i'm trying to remove the prongs and i have no idea how to
and i searched but seems that people found a way to solve it =\
can anyone tell me how?
and what should i do if one of my screws dropped into the engine floor..
its the screw that tightens the intake box (unscrewed too fast.... UGH)
I couldn't find it.. is it safe to drive around?
Thanks!
Old Jan 4, 2011 | 05:24 PM
taejin09's Avatar
taejin09
it is safe to drive with a few things down there and it will eventually fall out. I have dropped a screw driver down the bay and everything is fine.
Old Jan 4, 2011 | 05:32 PM
SB350's Avatar
SB350
Can't you just plug the harness in upside-down since the polarity is reversed?
Old Jan 4, 2011 | 05:35 PM
IS250TW's Avatar
IS250TW
CL Folding 25,000
no... there's a ┴ like matches both male and female of the plug
so i have to pull out the prongs and put it back in the up side down way =\
Old Jan 4, 2011 | 06:41 PM
papaalex's Avatar
papaalex
try looking at this thread, this is what I used when I first installed my Volt kit
https://www.clublexus.com/forums/is-...tallation.html
Old Jan 4, 2011 | 06:45 PM
ScKcBc's Avatar
ScKcBc
hence why i use DDM, you can turn the plug around no prob
Old Jan 4, 2011 | 06:46 PM
IS250TW's Avatar
IS250TW
CL Folding 25,000
I did looked at it when i searched
"That can easily be done by removing the prongs from the connector and switching it."
But i didn't know how to remove the prongs =\
is it just to pull out as hard as you can?
I was pulling it hard and nothing moved
Old Jan 4, 2011 | 07:34 PM
IS250TW's Avatar
IS250TW
CL Folding 25,000
its like this if i didn't explain it clear enough
Old Jan 4, 2011 | 07:46 PM
Fuzzie's Avatar
Fuzzie
hmm. have you tried jsut drilling that narrow part off? lol
Old Jan 4, 2011 | 07:53 PM
whitecel's Avatar
whitecel
worst case scenario just do what we did on my friend's car. We just cut the wires and soldered them together. Or you can just use male and female connectors
Old Jan 4, 2011 | 07:55 PM
JoeCombs's Avatar
JoeCombs
just twist it and plug it in, if that doesnt work, change something else and plug it it lol thats how i installed my volt kit, just keep playing with it till it works. of you really want to be sure, PM XENONDEPOT he's on these forms often, or give them a call.
Old Jan 4, 2011 | 10:47 PM
Jetfire's Avatar
Jetfire
Royale with cheese
you pop in one of those flathead precision screwdriver from the bottom of the tube on the middle side. it's just a small latch kinda thing holding the connectors in place.
Old Jan 5, 2011 | 03:59 AM
IS250TW's Avatar
IS250TW
CL Folding 25,000
Thank you!! this is a life saver didn't think of that before lol
but i'm stuck on the following.. i still can't pull the wires out
Do I just pull as hard as possible to pull it out or there are some switch there?
Old Jan 5, 2011 | 08:52 PM
busdepot's Avatar
busdepot
CL Folding 10,000
There should be a tab you can push up to unlock the harness. It's pretty standard on any OEM or Aftermarket lighting harness. They are stubborn though, I know what you mean. You're gonna have to pull hard, but make sure you're pulling on the plastic, not the wires. I found side to side while pulling helped.
Old Jan 5, 2011 | 10:37 PM
rza8gamma's Avatar
rza8gamma
I had the exact same problem when i installed my volts. Your not going to be able to pull the connectors out from the harness so stop trying. What i did is what whitecell recommended you do, cut the wires before they connect to the harness and solder one side (black) to the other side (white). Think of it like an hour glass where one side connects to the other.
