Will those wheels fit? START HERE.
'08 IS350 w/ stock suspension. Will need a cheap set of wheels to put winter tires on; will these fit safely? They're 40 offset in front and back; should be ok in front but am I pushing it in the rear? Also, if I go F-Sport suspension in future, will they still be ok?
Link to wheels:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Link to wheels:
Link to wheels:-link snip-
if you don't do fender mods and run the right tire sizes, yes, you will.
im looking to get a set of Wedssport SA-55M in the following sizes:
Fronts 19x9 (+38) Rears 19x10 (+40)
How wide can i go with the tires? i really dont like the stretched look but dont want it to rub. im on stock suspension but will be fitting F sport springs
hey thank for the help those wheels sold just as i was about to go look at them, but i found some other ones that are 18x9 all around with a +10 front and a +0 rear would that fit on an 07 is250?
235/35-19 + 275/30-19 for max treadwidth.
i would recommend 245/30-19 in the front, but that would be really pushing it.
not without more fender work than what you were looking at originally.
hello fellow member,
Planing on buying new set of wheel for my is250 RWD. Neither a set of 18x8 and 18x9 with 38 offset all around. Would this fit perfectly without any fender modding ? best tires setup ?
or my second though is Varrstoen es1.1.2 19x9 +22 and 19x11 +25. How much fender modding i need to run this setup ? with best tires setup ?
Will be drop on megan coil
Please help a newbie like me lol thanks in advance
Would i be better off not going for such an aggressive wheel? Whats the biggest/widest you can go with a properly fitted tyre with no streatch in the side wall?
those aren't "stretch" sizes. you'll be safely within limits.
[QUOTE=projectdna;7410669]yes, those will fit without fender modding. just re-use your oem 18" tires (225/40-18 + 255/40-18).
you'll need to roll your fenders flat + natural pull, shave rear fender tabs, remove front fender bolt and bend the fender tab out of the way.
thanks for helping me out. I am probably going to settle for 18" for now and reuse my tires. Too much rendering modding for me. Haven't find a place near home to do the fender modding lol
