Will those wheels fit? START HERE.
Old Sep 9, 2012 | 08:19 PM
  #3826
dci4life's Avatar
dci4life
So i have narrowed it down to 2 different wheels options for my 2006 IS250 AWD
Can I run a 18 X 8.75 + 20 Front
18 X 9.75 + 20 Rear (My rear Fenders have been rolled)
Without problems. I hear AWD shouldn't run a Staggered Or would this fit
18 X 9.5 +25 Front and Rear (my rear fenders have been rolled)
Old Sep 10, 2012 | 06:54 AM
  #3827
JBeneRN's Avatar
JBeneRN
I live in cincinnati ohio
Old Sep 13, 2012 | 04:23 PM
  #3828
PlacidBoi's Avatar
PlacidBoi
Sorry to bring this thread up but I suppose it's what its for!
Here's my question
This is the specs for the wheels im looking at
19x8.5 +35 19x10 +42 wrapped in Hankook V12 255/35/19 275/35/19
I am dropped on Tein SS Coilovers
How low do you think I can drop before needing to roll any fenders? Will I need spacers to make it look flush?
Here are some pictures of how my car sits as of today
http://imgur.com/jLNi7
https://i.imgur.com/OLAyQ.jpg
Much appreciated!
-Sean
Old Sep 13, 2012 | 05:14 PM
  #3829
MyIS350G's Avatar
MyIS350G
You might better off stay with the same size, 18x8.5 +20 will be fine with fenders rolled, 18x9.5+25 will be fine for front and rear as well.
Here's my question
Much appreciated!
-Sean
those are fat tires! you might need something smaller.225/35/19 and 255 or 265/35/19 if you wanna drop even a little
Old Sep 13, 2012 | 05:51 PM
  #3830
J2NICEE's Avatar
J2NICEE
When i put aftermarket wheels on will i have to buy new TPMS sensors or will the tire shop just switch them from my stock tires?
Old Sep 14, 2012 | 06:47 AM
  #3831
bboysunone's Avatar
bboysunone
You can tell them to switch them to your new wheel
Other why your tire sensor might come on on the gauge. There is a way to trick the system if u don't want to put the sensor in your new wheel. It's call "pipe bombing".
Old Sep 14, 2012 | 01:31 PM
  #3832
J2NICEE's Avatar
J2NICEE
Thanks bro I ended up just buying new sensors
Old Sep 14, 2012 | 02:27 PM
  #3833
PlacidBoi's Avatar
PlacidBoi
Hey guys. For this spec, 19x8.5+35 19x10+42 Forgestar f14 wheels, what tires should I run?
I like thinner tires but I am a complete dummy with this stuff. I'm dropped on Tein SS coils and I want to drop to near max. What tire size should I ask for? Much appreciated thanks!
Lemme know if fender rolling is needed. I was told Tein SS coils aren't that low of a drop even at max.
Here's a picture of my car ATM. I can drop about .75 inchs more and that'll be max
Old Sep 14, 2012 | 03:04 PM
  #3834
pchan0's Avatar
pchan0
You don't need a roll, you can go with 235/35/19, 275/30/19 for a little more tire or 225/35/19, 265/30/19 for a little stretch.
Old Sep 14, 2012 | 03:16 PM
  #3835
PlacidBoi's Avatar
PlacidBoi
Another recommended me 225/40/19 for a thinner look. I thought the lower the middle number was, the thicker the tires? I am truly confused and another member above said 275 was too meaty 0__0"
Old Sep 14, 2012 | 05:31 PM
  #3836
J2NICEE's Avatar
J2NICEE
225= the width of the tire, 40= the profile of the tire, the lower the number the thinner the tire around the wheel and 19 is wheel size obviously.
I just got new tires and went with a 35 profile which is less than OEM tires, if you want wider tires increase the first number, if you want more tire going around the wheel increase the second number, hope this makes some sense
Old Sep 14, 2012 | 06:07 PM
  #3837
PlacidBoi's Avatar
PlacidBoi
Thank you! Helped me a lot
So can I roll and drop a lot with
225/30/19 and 265/30/19 with the offset listed above?
Or is there no such tires?
Old Sep 18, 2012 | 01:15 PM
  #3838
ISCjonny's Avatar
ISCjonny
Need the wheel experts help. Submitting specs for new wheels tomorrow. Wanted to confirm these sizes.
19x9 +28
19x10.5 +32
If my calculations are correct. Should work with minor stretch and shaved rear fenders and front bumper tab relocation.
Old Sep 18, 2012 | 01:22 PM
  #3839
cookies's Avatar
cookies
18x8+8
18x9+8
Old Sep 18, 2012 | 01:50 PM
  #3840
projectdna's Avatar
projectdna
incorrect.
225/35-19 + 265/30-19 if you want to keep your fenders unmodified. 225/40-19 is oem-size for the IS-F but not for the ISx50's. (btw, those sizes are safe for their respective wheel widths, in case you were wondering).
the middle number is the aspect ratio of sidewall height to the treadwidth. for example, if a 225 tire has a 35-series aspect ratio, that means the sidewall height is 35% of the treadwidth, or 78.75 mm.
i would not recommend going any lower than what your current ride height is unless you plan for fender modifications.
19x9 +28
19x10.5 +32
correct.
Originally Posted by cookies
18x8+8
18x9+8
that's going to require a bit of fender pulling and tire stretching.
