Will those wheels fit? START HERE.
Old Jul 17, 2012 | 11:53 AM
  #3706
Kvs_350's Avatar
Kvs_350
Default Volk sf challenge
Hi I'm planning to get a set of Volk sf challenge on my is350 19x8.5 +21 offset and 19x9.5 +28 offset will these offset fit? I know it might require fender rolling
Old Jul 17, 2012 | 12:22 PM
  #3707
Cuztom350's Avatar
Cuztom350
Im looking at Avant Garde M310s in hyper silver to fit on my is350. The specs on the front wheel are 19x9.5, bolt pattern 5x114.3 with a 20 or 25mm offset. The rear wheels specs are 19x11 with a 5x114.3 bolt pattern and an offset of 18mm. the website says these wheels wont fit. what would i have to do to get these to fit without rubbing.
Old Jul 17, 2012 | 12:44 PM
  #3708
projectdna's Avatar
projectdna
depends on your ride height.
but yes, it will require fender rolling and modding the fender tabs. front fender tab bolt will need to go, while the rear will need to be shaved down.
215/35-19 + 245/35-19 is the widest tire sizes you can run.
fronts will require a roll and a light pull, along with removal of the fender tab bolts. fender tabs will need to be removed. 225/35-19.
rear will require a solid roll and a pull. shave the fender tabs down. 255/35-19.
and after all of that, you still might rub.
Old Jul 17, 2012 | 12:51 PM
  #3709
Cuztom350's Avatar
Cuztom350
So the reason they would rub and require fender roll is because the wheels are wide correct? or is it an offset issue that I could fix with spacers. thanks, sorry im new on this.
Old Jul 17, 2012 | 12:57 PM
  #3710
projectdna's Avatar
projectdna
partially correct.
the reasons you will have clearance issues are because the wheels are wide, have low offset, AND require running stretched tires.
btw, rules of thumb regarding offset:
** lower offsets = wheels stick out
** higher offsets = wheels sink in
and by running spacers, you are effectively lowering your offsets even more than they already are.
Old Jul 17, 2012 | 01:20 PM
  #3711
Cuztom350's Avatar
Cuztom350
Here is the wheel info just to make sure I didnt give wrong facts. so a +18mm offset is to low? it needs a higher offset such as a 35 or 40mm? which cannot be done by spacers because it would make the offset even lower sticking the wheels out more bringing them closer to the fender. did i get that right?
Old Jul 17, 2012 | 01:39 PM
  #3712
projectdna's Avatar
projectdna
-attachment snip-
actually, 19x11 +18 will stick out very far past the fender edge.
Old Jul 17, 2012 | 03:52 PM
  #3713
DocFreud's Avatar
DocFreud
i should say rolled and (naturally) pulled, along with shaved fender tabs.
the rigid rules and regulations is a great way to get fake wheels off the street. unfortunately, we don't have any of that here, but i digress.
we have more then enough fake rims that are legal, mostly le mans fakes for VW bolt pattern *lol* for us, usa is like a car paradise.
sorry for the off topic.
thanks for your answer, again
Old Jul 17, 2012 | 03:56 PM
  #3714
2IS's Avatar
2IS
not likely.
Will the front sit nicely and not stick out? I want it to be close to flush without having to roll the fenders. thanks.
Old Jul 17, 2012 | 04:25 PM
  #3715
MyIS350G's Avatar
MyIS350G
those are nice, but 19x11 +18!
those rear lips gonna stick out almost 2 inches!
Old Jul 17, 2012 | 04:40 PM
  #3716
Cuztom350's Avatar
Cuztom350
ya i really like these better than the dolphin gray but theres no way to make them work, and the 11x9.5 have a +25 offset which im guessing also cant work without fender work
Old Jul 17, 2012 | 04:45 PM
  #3717
projectdna's Avatar
projectdna
if you don't want to roll your fenders, you might want to go with something with slightly higher offsets.
Old Jul 17, 2012 | 04:58 PM
  #3718
projectdna's Avatar
projectdna
correction.
you can make them work.
just depends on how far you're willing to go to make them work, and how much functionality you're willing to compromise.
Old Jul 17, 2012 | 05:03 PM
  #3719
Cuztom350's Avatar
Cuztom350
not too far, I thought spacers would do the trick.
thanks for all your help, you guys are great
Old Jul 17, 2012 | 05:07 PM
  #3720
projectdna's Avatar
projectdna
spacers would effectively decrease offset and push the wheels out even farther. you don't want that given the wheel specs you were inquiring about.
