Will those wheels fit? START HERE.
Old Jun 3, 2011 | 05:53 PM
  #2116
bforbrian's Avatar
bforbrian
Originally Posted by sushiboi
I'm thinking about getting some 19x8.5E30 and 19x9.5E25 and some springs for a 2" drop. Does anyone know what tire sizes I can run with these without any mods to the fenders? I'm currently leasing my car, and I don't think I can mod the body.
With a 2" drop, some camber will be dialed in naturally.
225/35-19 up front with 235/35-19 will work fine.
If you wanted to be absolutely sure the rears won't rub (The fronts definitely won't), then I would run 225/35-19 all around, with a good stretch tire (i.e. Dunlop Direzza DZ101, Falken 452, Nexens and Nankangs). That is, if you don't mind a narrow tire on a relatively wide wheel.
Old Jun 3, 2011 | 08:02 PM
  #2117
sushiboi's Avatar
sushiboi
Thanks for the input guys.
@bforbrian - I don't think I could do with thin tires. I couldn't get used to the driving.
Guess I'll have to try to find another set.
Old Jun 5, 2011 | 11:01 AM
  #2118
bdoggie28's Avatar
bdoggie28
Hello all. Im currently looking at the forgestar f14 wheels in 18s for my is250. Ive never purchased wheels before so this is new to me. Heres my options for the front:
18x8.5, 35mm, 40mm, or 45mm offset
Rear:
18x9.5, 35mm, 40mm, or 45mm offset
I just need advice on what will work and look the best with no rubbing issues.
Thanks!
Old Jun 5, 2011 | 12:47 PM
  #2119
dmk08's Avatar
dmk08
Rear:
Thanks!
I cant answer your question specifically but I would just order from Forgestar directly if you're not. Peter was very helpful when I was ordering my wheels. They can help you get the right size. I went +35 in the front and +42 in the rear but they are 19's. (Forgestar F14F)
Old Jun 5, 2011 | 04:32 PM
  #2120
bdoggie28's Avatar
bdoggie28
Thanks for the quick response!
Old Jun 6, 2011 | 08:39 AM
  #2121
murder's Avatar
murder
Default I don't know what i'm doing.
I have a 2008 is250. I want to get a set of Lorenzo WL19 wheels in black. They only make them in 18" and 20"....Are 18's too small?
I don't think I can choose the offset of the wheel, as it appears the only come as follows:
18x8 front +45mm 18x9.5 rear +48mm
20x8.5 front +35mm and 20x9.5 +35mm
Will those offsets work?
Old Jun 6, 2011 | 09:13 AM
  #2122
Mv350's Avatar
Mv350
both offsets will work without fender mods, and i prefer 18's on a 2is over 20's and most of the time over 19's also
Old Jun 7, 2011 | 05:02 PM
  #2123
Fojo's Avatar
Fojo
i can get my hands on a set of Emotion XC8 18x9.5 +20 5x114.3
would i be able to stretch the stock 225/40r/18 tires on them? what about the offset? Work rep said something about too agressive... what say you fellas?
Old Jun 7, 2011 | 05:09 PM
  #2124
Mv350's Avatar
Mv350
thatll work all around. you can tuck 9.5+20 in the rear completely on coils . just roll all around, mod the front bumper tab and your set
Old Jun 10, 2011 | 08:05 PM
  #2125
sleekbrian's Avatar
sleekbrian
I have a IS250 AWD and am looking to get Varrstoen ES 1.1.1 (BBS reps). The specs are 18x9 with 40 offset. I will be using that wheel spec all around, nonstaggered. I just wanted to make sure i can run this with no modification or wheel spacers. I will have a conservative drop with BCR coilovers. IF this setup will work, what size tires do i need?
Old Jun 11, 2011 | 03:17 PM
  #2126
Willis1550's Avatar
Willis1550
^^^^^^^ I thought you were getting those Enkei's?
I'm looking at VS-XX's:
19x8.5 +29, O Disk, 72 mm lip, 225/35/19 (AWD)
19x10 +36, O Disk, 84 mm lip, 265/30/19 (AWD)
Can anyone comment on the Disk Type, or if there is a better way to go? MV, Project?
Old Jun 11, 2011 | 10:35 PM
  #2127
inno's Avatar
inno
Hey guys, checking on fitment:
Front: 19x8.5 +30
Rear: 19x9.5 +25
I know 8.5/9.5 usually work F/R but didn't know if the offsets would be too low. I am going to be on coilovers. What type of fender mods would I need if any?
Thanks!
  #2128
inno's Avatar
inno
Also, any comments on tires?
235/35/19 F and 275/30/19 R ?
Old Jun 11, 2011 | 11:36 PM
  #2129
projectdna's Avatar
projectdna
Front: 19x8.5 +30
Rear: 19x9.5 +25
Thanks!
offsets are considerably low, enough to need fender mods.
roll + shave/trim fender/bumper tabs.
if your ride height is conservative enough, you MIGHT be able to get away with it.
any lower, and those sizes will be too wide - even w/ a 30-series in the rear.
225/35-19 up front, 245/35-19 in the rear.
you might be able to stuff a 255/35-19 in the rear if you really tried, but that's pushing clearance w/ rolled fenders and shaved/trimmed tabs.
Old Jun 12, 2011 | 10:44 AM
  #2130
ltzSupra's Avatar
ltzSupra
Will 18x9.5F 18x10.5R +30 all around need fender mods? I have megan ez coils.
