Will those wheels fit? START HERE.
I'm about to order a set of wheels but is wondering if the following spec would work..
19x8.5 +23
19x10 +29
My shop suggests to go with below to be safer
19x9 +31
19x10 +32
Im willing to stretch and roll fender, def. no pull, and i have coils to adjust height.
Will the first specs work? Thanks in advance.
19x8.5 +23
19x10 +29
19x9 +31
19x10 +32
Thanks again!
225/40-18 + 235/40-18
19x8.5 +23
19x10 +29
19x9 +31
19x10 +32
19x8.5 +23
19x10 +29
19x9 +31
19x10 +32
19 x 8.5 +23 -> 215/35-19
19 x 9 +31 -> 225/35-19
regardless, either set-up will require modified fenders.
btw, if you roll your fenders, they're going to be slightly pulled from the natural forces exerted onto the fenders by the fender roller.
you're going to have the same frontspacing for the front wheels. only the backspacing will increase. this will allow you to run slightly-wider tires.
19 x 9 +26 -> 225/35-19
19 x 10 +29 -> 255/35-19
Am I correct on the tire size?
other alternatives:
1. go with a square wheel-tire set-up
2. go with higher offset in the rear
255/35-18 won't have enough of a stretch on 18x10 for you to clear the fenders given the +20 offset. you can try 245/40-18 if you want to keep the oem rolling diameter closer.
other alternatives:
other alternatives:
Just wanna give a big thanks to you guys for helping me/us out.
Just installed 235/35/19 on my 8.5" wheel + 255/35/19 on a 9.5" .. I am really surprised how similar it feels to the stock 17" setup , was expecting ride to be much stiffer but it was really ok .
Guess my Bridgestones on the 17" were too hard , I installed Federal tires btw on the new wheels.
would i be ok with just a fender roll ? cause i dont wanna mess around with the plastic liners in my wheel wells etc. also what tire size do u reccomend for this set-up? Im new to this whole thing and dont really wanna modify my fenders other then a fender roll, worst case i'll shop for new wheels, i just really like the ones and they only come in the said offsets +22 or+30
for 19x9.5/10.5 +22, you'll need rolled + lightly-pulled fenders. typically, the force exerted by the fender roller onto the fender from the inside will effectively "pull" the fenders out slightly.
for tire sizes, 225/35-19 and 245/35-19, though depending on how much of a light pull you have on your rear fenders you can run 265/30-19 as well.
on a related note... let me guess, you're looking at varstoen wheels?
I ran a set up pretty close to this... 9.5 +23 / 10.5 +21. Just roll the rears and take a heat gun to the front fender liners. Also I had megan camber arms in the rear too...With a 225/35 245/35 tire setup to get it all decently flush. Good luck
