Will those wheels fit? START HERE.
This might be a newb question, but here goes nothing.
For a RWD 2IS, what is the rule on running staggered setup? It is required? Or we can basically roll similar width all around given wheel well will suffice?
I was thinking of running 19x9.5 all around with the offset of 22... will that offset be too big for the front since it is 9.5 with 22 OS?
I am a total noob with wheel fitment, please don't hate
rear will need a pull just so you know. if no pull you have to tuck the WHOLE tire and run -6.5* camber with the addition of megan camber and toe links.
the front will NEED A PULL and removal of the bumper tab. you will need to stretch a 235/35 and itll fit
this is a very aggressive setup but will turn out great if you go ahead with it
I'm still hesitant cause the front seems way too wide...but this is very tempting.
I've removed the tab and cut parts of the front fender where there is potruding metal behind it, then shaved down the metal to get more clearance. So I will just need to pull all the fenders and run stretched tires all around?
with the rear just roll or shave the guards, you can run the same size tires if you wish or you can run like a 235/35 or 245/35
https://www.clublexus.com/forums/whe...4-3-cheap.html
245/30-19 is too short of a tire and will throw off the speedometer and odometer. the outside shoulder of the tire may not clear the fender/fender tabs on suspension compression.
235/35-19 will work.
So is it the fender tab that kills my dreams of 245 width tires? Would removing that revitalize my dreams or would it need more work?
245/30-19 is actually closer to 225/40-18 in terms of overall height than 245/35-19 is; the 35-series tire is 5/8" taller, while the 30-series tire is a little over a 1/4" shorter.
in short, it is shorter, but not "too short".
however, it won't be the tire height that'll be the issue but the tire treadwidth. if you don't have enough clearance between the shoulder of the tire and the fender at a static ride height and suspension compression, you'll end up with either shredded tires or crumpled fenders.
from earlier:
given this, you'll have issues running 245 in the front.
either plan for fender work (rolled or shaved fenders + shaved fender tabs), thinner-treadwidth tires, and/or different spec'd wheels.
Trying to pull off these wheels. If possible without destroying my front end.
Would this work without a pull? My rear fender is shaved and the fronts are rolled, tabs modded, heat gunned and trimmed liner.
What size tire do i need, i'm trying to slightly tuck if possible.
19x9.5 +15mm
19x11.0 +5mm
19x9.5 +15mm
19x11.0 +5mm
you're welcome.
btw, understand that i'm not trying to discourage you from running 245's up front.
however, reality is, 245 up front will require a very small window of the right wheel specs, or else you'll need fender modifications to compensate (read: create more clearance).
Mv350?
