Climate control problems
Old May 22, 2007 | 07:52 AM
Toptier's Avatar
Toptier
Default Climate control problems
When I start my car the climate control does not turn on and the front defrost button blinks. I am not able to do anything with the climate control for about a min. Then the nav screen displays climate control OFF, then I’m able to use the climate controls. If you’re asking I do not turn off the climate control when I turn off the car I leave it on Auto. It just started doing it this weekend. What’s weird is if I just put the car to ON the climate control works fine, it’s just when I start the car it does it. I already made an appointment with Lexus.
Anyone else have this happen?
Old May 22, 2007 | 08:11 AM
ben_r_'s Avatar
ben_r_
I would take that one to the dealer just in case...
Old May 22, 2007 | 08:17 AM
SonnyIs350's Avatar
SonnyIs350
^^^ Me 2!!
Old May 22, 2007 | 08:20 AM
chaos6458's Avatar
chaos6458
u should! take it to the dealer!
Old May 22, 2007 | 08:23 AM
Buds's Avatar
Buds
Is it just me or are we seeing more and more of these quirky problems? I'm starting to see why in Consumer Reports the only category in which the IS did not excel was the "Electrical" category...
Old May 22, 2007 | 08:28 AM
ben_r_'s Avatar
ben_r_
Well, I just kinda look at it this way.... With so many more things in a car there is just so many more things to go wrong. It does seem like Toyotas largest problem is in fact Denso, as I have noticed a lot of nav problems...
Old May 22, 2007 | 08:31 AM
PhilipMSPT's Avatar
PhilipMSPT
Cycle Savant
That is odd. I haven't heard of anything like that from other members...
Old May 22, 2007 | 08:33 AM
15951's Avatar
15951
I've only seen a few posts about issues around here. That's pretty remarkable given the complexity of this car.
Old May 22, 2007 | 10:26 AM
Gtidan's Avatar
Gtidan
Why? From what I'm reading here there is nothing wrong. The reason the climate system does not come on immediately is that it waits for the car to warm up some until it can provide heat in the cabin rather than blow cold air.
When the temperature outside is warmer I've noticed it comes on right away. Look, the car is pretty sophisticated so just let it do it's thing before you dump on Lexus....
Old May 22, 2007 | 10:44 AM
Toptier's Avatar
Toptier
well it would be OK if it were cold out. But it's 90 degrees out and the inside of the car is 100+
Old May 22, 2007 | 11:43 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
possible software problems (esp owners with nav)?
mine is non-nav and i didnt have any problems so far.....?
Old May 22, 2007 | 12:40 PM
c5mtl's Avatar
c5mtl
same problem here....light flashes at least 5 times and then turns on at 25deg(cdn car).....been about 2 months with that problem
Old May 23, 2007 | 04:27 PM
Toptier's Avatar
Toptier
the dealer said that they have to order a new AC control module or something like that. So the car will be back to the dealer when the part comes in. Hopefully it work after.
Geremology101
Dec 6, 2022 11:06 PM
rbigshow04
Feb 15, 2010 03:55 PM
GoldieLex
Jun 16, 2005 03:18 PM
Jasoneo5
Jan 28, 2004 08:50 AM
