could this be mounted on the trunk. are there holes being the stock emblem? or is this product strictly for the front grill. id really like to find a way to put it on the trunk if its possible. http://www.lextasy.com/Altezza-Emblem.htm
There are no holes for the rear emblems. If you want an Altezza badge in back, I think you should at least get the proper one (and remove the other emblems).
Mr_Singh's car:
I wouldn't suggest it, but if you REALLY want to use that emblem in back, you could always grind down the mounting tabs and stick it on with double-sided tape.
that badge from the lextasty site is for the front grill only. its is small and would be too small for the trunk. the badge for the trunk is held on by tape only.
