IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
urgent help needed!~!!
Old Jul 17, 2009 | 01:55 PM
3rdelement's Avatar
3rdelement
Default urgent help needed!~!!
my battery is dead and my car wont unlock so that i can pop the hood and charge the battery.
help!
Old Jul 17, 2009 | 02:20 PM
Debonair's Avatar
Debonair
You can't open the door with the key?
For give me if there is something I do not know.
Old Jul 17, 2009 | 02:25 PM
3rdelement's Avatar
3rdelement
only the trunk. so you have to take off the ski pass which is zippered from the other side. then you manually unlock the rear door with the broom handle. then from there you unlock the front. then pop thehood
Old Jul 17, 2009 | 02:30 PM
Debonair's Avatar
Debonair
No key hole in the drivers door huh, weird.
Old Jul 17, 2009 | 02:31 PM
3rdelement's Avatar
3rdelement
there is one. but the key didnt open it. that was the first thing i tried.
Old Jul 17, 2009 | 02:34 PM
Debonair's Avatar
Debonair
Ah ha! That would be the missing variable I was unaware of. Try another key if you have one, second master or valet. If not through the trunk you go.
Old Jul 17, 2009 | 02:56 PM
rvalero's Avatar
rvalero
One of my keys doesn't work very well in the driver's side door. Try gently jiggling it into the key hole while applying pressure. That works for me. Do you see a red light on your key when you push a button?
Old Jul 17, 2009 | 04:44 PM
3rdelement's Avatar
3rdelement
so here is what ive found out through research and also through real life trial.
1.) the key (1) that i have is the one with the buttons on it, does open the door manually, but only if there is power.
2.) many lexus owners run into this issue. the valet key is the only one that manually unlocks all the time.
3.) i unlocked my trunk manually, removed my subs, unzipped the skipass(even though it was zipped from the inside), used a broom stick and unlocked my back door, then unlocked the front door and popped the hood. jumped the car, and im good to go now. how strange.
Old Jul 17, 2009 | 04:54 PM
rvalero's Avatar
rvalero
Your saying that a master key can't open the door manually if the car's battery is dead, but a valet key can. Weird...why would Lexus give a valet key a function that a master can't perform? Almost makes me want to disconnect my batt just to try it out.
Old Jul 17, 2009 | 09:25 PM
3rdelement's Avatar
3rdelement
if you do try it, pm me with your results.
Old Jul 17, 2009 | 10:17 PM
Faymester's Avatar
Faymester
+1 ... on the whole thing
No wait, my battery died once just after I got the car (left the lights on, oops, rookie error) & I opened my door w. the master key.
You guys are just strange
Glad it worked out for you though.
Old Jul 17, 2009 | 11:55 PM
3rdelement's Avatar
3rdelement
thanks.
btw feymester, whos the girl in your avatar?
b2884987
RX - 3rd Gen (2010-2015)
Apr 23, 2019 05:40 AM
LS430cb
Aug 4, 2016 06:05 PM
Stu
Oct 13, 2013 08:56 PM
lth40555
Jan 5, 2012 03:27 PM
superdudu
Jun 29, 2011 09:03 PM
