RX450h Mileage Thread
That’s great mileage! Why are our readings so completely different? I’m at about 1500-1800 ft above sea level & relatively flat. Local speed limits are 65 & below. US Highways are 70-75 & I-10 is 75-80mph. I don’t drive on I-10 very much.
Note that DocRock mentions a lot of hilly terrain at 25-35 mph speeds. Those are near perfect environments to get great mileage with the hybrids - coast downhill to regen while potentially braking and keep the batteries fully charged; and then on the uphill parts, there would be enough juice in the batteries to keep the electric motors going most of the time. Repeat the cycle when you crest the hill. You could go miles in those conditions without the engine kicking in at all.
Flat terrain and highway speeds are actually not good for hybrid mileage. On a flat road, you cannot take advantage of coasting downhill to regen the batteries. You'll just end up having the ICE come on more often to recharge the batteries, especially if you use EV mode too much. And of course at highway speeds, the brakes aren't used much, so there's even less regen happening.
Ironically, I believe the 450h gets better mileage on hilly terrain than on flat terrain. Here's an example: the climb to the summit of Cadillac Mountain at Acadia is about 1,000 feet over 3.5 miles. Obviously, the ICE is operating practically all the time. However, on the descent, the grade is sufficient for the ICE to completely shut down over the entire 3.5 miles while, simultaneously, regenerative braking is charging the hybrid battery. On our two trips up Cadillac, we followed the descent with a drive along the Park Loop Road (beautiful drive, BTW). The speed limit is 25 MPH and the road has some slightly hilly sections. Both times, with a fully-charged hybrid battery, I was able to drive more than 5 miles on the Park Loop Road with the ICE hardly ever engaging. And, my indicated MPG at that point was higher than before we started up Cadillac Mountain.
Practically our entire trip was on hilly terrain (the Appalachians were "with us" most of the time). But, the hits to MPG we took when going up a hill were more than compensated for by the electric motors carrying the load going downhill.
2020 RX450h fill up at 2,655 miles 8/12/21. Traveled 393 miles, all city, short trips mostly 14 miles each way, warm weather mostly a bit above 90 degrees F.
30.1 mpg calculated. The RX said 30.5 mpg. Filled up with QuikTrip Premium.
2020 RX450h fill up at 3,074 miles 9/25/21. Traveled 419.1 miles, all city, short trips mostly 14 miles each way, warm weather mostly a bit above 80 degrees F.
29.8 mpg calculated. The RX said 31.4 mpg. Filled up with QuikTrip Premium.
2020 RX450h fill up at 3,512 miles 11/12/21. Traveled 438 miles, all city, short trips mostly 14 miles each way, cooler weather mostly a bit above 70 degrees F.
30.2 mpg calculated. The RX said 29.4 mpg. The Lexus dealer filled it as a [size=13px]curtesy[/size].
I expect my mileage to drop off about 3-5 MPG during the winter months. The heater and defrosters (windshield, liftgate and mirrors), the steering wheel heater and the "bun warmers" all draw electric current. It takes the ICE longer to reach operating temperature. Fortunately, the traction battery is inside the car instead of being exposed to the outside temp once the cabin warms up.
I discovered with my previous hybrid that the bun warmers and steering wheel heater often kept me warm enough to minimize the use of the heater. Not the defrosters, though.
NOTE: This is the experience with my wife's 2020 RX 350. Not my 2021 RX 450h. I thought I had posted this in the RX 350 Mileage page. Sorry about the confusion.
We returned from Virginia on Thanksgiving Eve. It's a 220 mile trip of which about 90% is interstate (or otherwise limited-access) highways. Sunny, no wind to speak of. Mid 30s temps when we left; 40s most of the time. Typically about a 4-hour drive. Tank was full with winter gas.
Unfortunately, there were several stop-and-go traffic delays along the route (ironically, the DC Beltway flowed smoothly). That turned the trip into a more than 5-hour drive. Traffic backed up approaching Frederick, MD; on I-83 in Harrisburg, PA; several miles before the I-81/I-78 split east of Harrisburg; and, on the-always-annoying US 22 in the Lehigh Valley.
Nevertheless, we averaged 30 MPG. Not complaining.
2020 RX450h fill up at 3,934 miles 12/5/21. Traveled 422 miles, 50% city, short trips mostly 14 miles each way, 50% highway 70mph, weather mostly a bit above 50 degrees F.
29.7 mpg calculated. The RX said 29.3 mpg. Filled up with QuikTrip Premium.
Refueled just before my 12-month service at my Lexus dealer.
Here are my first-year mileage stats:
Miles driven: 7,103 (I estimate that about 75-80% were highway miles)
Gallons of fuel used (full tank to full tank): 196.25
MPG: 36.19
Average cost of fuel (always Top Tier Premium): $3.38 per gallon
Fuel cost per mile: $0.094
MPG: 36.19
2020 RX450h fill up at 4,326 miles 1/23/22. Traveled 391.4 miles, 100% city, short trips mostly 14 miles each way, 0% highway weather mostly cold..
27.3 mpg calculated. The RX said 28.5 mpg. Filled up with QuikTrip Premium.
2020 RX450h fill up at 4,651 miles 3/2/22. Traveled 325 miles, 100% city, short trips mostly 14 miles each way, 0% highway weather mostly 50F to 70F.
30.1 mpg calculated. The RX said 29.3 mpg. Filled up with Sam's Club Premium.
__________________
2020 RX450h Luxury Package, Atomic Silver, Black, 20" Michelin.
2013 ES300h UL, Starfire Pearl, Parchment, Michelin, LDA, ML, PCS, BSM, IPA, DRCC, PTO/C - Trade-in for RX450h.
2015 ES350 UL, Atomic Silver, Black, 18" Michelin, LDA, ML, PCS, BSM, IPA, DRCC, PTO/C. - Trade-in for RX450h
Member of the Lexus Advisory Board
__________________
