#Techstream
Old Dec 23, 2022 | 11:25 AM
  #121
Acrad's Avatar
Acrad
I couldn’t get live data with a the 1.4.x cables on my ‘12… a 2.0.4 cable worked fine for live data and Active Tests.
If you just need to perform customizations and pull codes a 1.4.x cable should be fine though.
Old Dec 23, 2022 | 12:04 PM
  #122
vanduker's Avatar
vanduker
10th Gear
Thank you. Any downside to the 2.0.4 cable other than cost? Looks like 108.00 on Amazon.
Old Dec 23, 2022 | 12:26 PM
  #123
Acrad's Avatar
Acrad
It would just be the cost IMO
Old Jan 17, 2023 | 02:08 PM
  #124
cha0tik's Avatar
cha0tik
5th Gear
Cloned sounds very convenient.
2020 has TPMS self-registration with tire swaps and as well as new sensors.
Would this be 2020 and onwards? I just picked up a 2023 and also want to get a different set of wheels for the winter, with their own set of OEM TPMS sensors.
And if self-registration works with the new sensors, would the spare tire impact this at all (assuming it has a sensor as well)?
Thanks in advance!
Old Jan 17, 2023 | 04:11 PM
  #125
IanG's Avatar
IanG
Thanks in advance!
Page 489-491 of the 2023 owner's manual, you need to "register ID codes" first then "initialize the tire pressure warning system" next.
The spare tire is re-registered during this process.
I have done this to mine for the past 2 winters swapping summers & winters, both sets have OEM sensors
Old Jan 17, 2023 | 05:01 PM
  #126
cha0tik's Avatar
cha0tik
5th Gear
Thanks for the reply, Ian!
So in essence, you just swapped sets of wheels with OEM sensors and they automatically registered every time?
Old Jan 17, 2023 | 05:35 PM
  #127
IanG's Avatar
IanG
You have to follow the process in the manual as I mentioned above, it is not automatic, you do it through the dash/steering wheel navigation screen, but don't need any special equipment or trip to the dealer.
Old Sep 14, 2023 | 10:15 AM
  #128
JRA2000TL's Avatar
JRA2000TL
Has anyone ever figured out the Techstream fatal error 0xc004001? I've searched the internet to the end of the universe. I purchased the 2.0.4 cable, which is what I'm told would fix it, and it will not work on our 2015 GX for live data. I've tried multiple versions of the software, and I'm running it on XP through Virtual Box. The irony is that it will read live data on my 2011 ES. All other functions work on both vehicles--just not the live data for the GX. I need this so my mechanic friend can look at the fuel trim values. I've had an intermittent code for EGR/MAF. I cleaned the MAF and TB; helped a little, but I still have a rough idle. No more codes. I'm hoping someone has a live data fix for this.
Old Sep 14, 2023 | 05:09 PM
  #129
John00's Avatar
John00
unsure if thats even a techstream error or a windows error during techstream.
check Idel at +/- some rpm, <=100 deviation.
start, put in drive, still rough?
rough when steadily pressing accelerator to add 50 rpm?
if no, could be TB resistive trace
also you should be able to read at least some fuel trim info live just using a generic odb2 with torque
Old Jan 7, 2024 | 07:45 PM
  #130
psun786's Avatar
psun786
The customization function on v16 and v18.00.008 doesn't seem to work on my 2018 GX. The tab is present on the left but does nothing when I click on the actual item. Is there any fix other than downgrade to v10.30.029? Thanks
MattBianco
LX - 3rd Gen (2008-2021)
Dec 8, 2015 12:02 PM
frank69m
GX - 2nd Gen (2010-2023)
14
Jul 22, 2013 10:33 AM
WTJ
GX - 1st Gen (2003-2009)
Mar 4, 2013 07:52 PM
Maven
Aug 5, 2010 05:08 PM
ERC4
Aug 31, 2009 10:38 AM
