Having same problems
Old Jan 5, 2023 | 03:16 PM
Jdreher17's Avatar
Jdreher17
6th Gear
Default Having same problems
I originally posted this and couple months with no response. I’ve taken my car to several auto electric shops and keep getting the run around. Could really use some help thanks.
“Audio Navigation system only works in when key is turned to on position, When engine is turned on screen is completely black and unresponsive, audio goes in and out. A/C is able to be somewhat controlled by physical buttons. I’ve checked all the fuses none are blown, I have also removed battery terminal to try and reset. I have also removed and reinstalled the unit and amp with no luck.
Thanks”
Old Jan 6, 2023 | 06:06 PM
NTH's Avatar
NTH
Checked for codes?
A weak battery can also cause all sorts of issues.
Old Jan 8, 2023 | 07:38 PM
Patton6964's Avatar
Patton6964
Maybe a bad navi? What year?
Old Jan 9, 2023 | 09:50 AM
Jdreher17's Avatar
Jdreher17
6th Gear
Originally Posted by NTH
Checked for codes?
Yes i have checked codes using OBD2 meter no codes
ran the diagnostic and said battery was good
Old Jan 9, 2023 | 10:17 AM
Jdreher17's Avatar
Jdreher17
6th Gear
The year is 03
Old Jan 11, 2023 | 03:39 AM
NTH's Avatar
NTH
What do you mean ran diagnostics- You took it somewhere to load test? Also how old is your battery?
Old Jan 12, 2023 | 05:05 PM
Jdreher17's Avatar
Jdreher17
6th Gear
There is a self diagnostic test you can run if you hold the info button down and flash the lights 3 times and the battery was recently replaced a little over a year ago.
Old Jan 12, 2023 | 05:20 PM
Jdreher17's Avatar
Jdreher17
6th Gear
The first two pictures are when the engine isn’t on the second two are when key is turned over
Old Jan 13, 2023 | 07:39 AM
Patton6964's Avatar
Patton6964
Battery looks good, I would suggest swapping navi's if possible to see if its the unit itself.
Old Jan 13, 2023 | 08:14 AM
cssnms's Avatar
cssnms
Maybe worth taking it to the dealer to see if they can do a system update.
cdgarske
Mar 8, 2021 09:09 AM
Conrad787
Apr 22, 2019 02:41 PM
nfordhk
Oct 17, 2010 12:18 AM
xnxoxsx
Mar 25, 2010 09:51 AM
tyoung88
GX - 1st Gen (2003-2009)
Nov 7, 2007 03:54 AM
