Auto side Mirrors not working right
The mirrors on our 2015 GS with luxury package no longer tilt down when in reverse. This started right after a Lexus service visit. They work normally in other respects and fold normally. Is there some setting I’m overlooking? Would prefer to deal with this at home since the dealer is not that close. There is a Toyota dealer nearby though.
Where is the rocker switch currently sitting for the left/right mirror control? On my 2016 it has to be in a position where the left or right mirror is selected and not in the neutral position.
Also it may been adjusted at the dealer so to adjust back, just place the car in reverse and lower the mirror to your desired reverse angle. The car will save the setting and go back to it as long as the rocker switch is in the Left or Right position.
If the motor is gone, you will find out very quickly during the adjustment.
Try putting the car in reverse, with break pedal down, adjust the left and right mirrors down and where you want them in reverse.
Now put in park and the mirrors should go back to where they were for normal driving.
Problem solved hopefully.
Likely he just needs to set the reverse positions because dealer reset it or just make sure left/right mirror is selected. If it’s not selected thats why it’s not tilting in reverse.
Took me a min the first time to realize this, but mine was just a case of the switch being moved to the neutral position.
taylorjste
Jun 21, 2011 04:20 AM
