Bluetooth Issue's
Old May 17, 2016 | 08:38 AM
bigblack06's Avatar
bigblack06
Default Bluetooth Issue's
So I started my car yesterday and the Bluetooth wasn't connected not sure but I figured I turn it off and then back on and it should work. It literally does not show up anymore as an option I'm not sure what the problem is but I don't really want to schedule an appointment if it can be fixed any takers.
Old May 17, 2016 | 09:31 AM
bclexus's Avatar
bclexus
Is the car not detecting your phone, or the phone not detecting the car? I assume your phone's Bluetooth is on and visible to the car. Does your phone have 'Trusted Devices' where the car's Bluetooth may be listed?
Old May 17, 2016 | 09:42 AM
bigblack06's Avatar
bigblack06
It is actually both in the settings for phone the Bluetooth option is grayed out and can not be clicked on, my phone does not see it anymore, and it is still
Old May 17, 2016 | 09:44 AM
jsndin's Avatar
jsndin
Have you tried resetting the settings to factory?
Old May 17, 2016 | 10:42 AM
bigblack06's Avatar
bigblack06
I have not but will try this when I get home.
Old May 17, 2016 | 11:07 AM
jtrue28's Avatar
jtrue28
There is/was a TSB for Bluetooth connectivity. Not sure if it applies to you car, but your symptoms sound very familiar.
Old May 17, 2016 | 12:48 PM
islandbeef's Avatar
islandbeef
I was going to either recommend you do this or "forget the device" and re-pair to the car. It's when the phone requires an OS update, I get nervous about losing basic functions.
Old May 18, 2016 | 06:59 AM
bigblack06's Avatar
bigblack06
Yea, I'm bringing it in for service today hoepfully it can be resolved.
Old May 18, 2016 | 07:58 AM
bigblack06's Avatar
bigblack06
Here is the TSB for anyone that is having the same issue.
Bluetooth.pdf
Old May 18, 2016 | 08:02 AM
popping's Avatar
popping
FWIW, i did this TSB two years ago and it made bluetooth issues worse. But i was using an older android phone and version of android. I've since updated and now running marshmallow (6.1) and haven't had issues since lollipop.
Old May 18, 2016 | 11:03 AM
jtrue28's Avatar
jtrue28
You're driving a 2014 though, so that likely won't help.
Old Sep 8, 2016 | 07:22 AM
spoogenet's Avatar
spoogenet
I have a 2014 and just experienced this issue today. Yesterday afternoon, Bluetooth worked just fine. This morning, I had a red slash through the signal indicator and it would not connect to my phone, but still showed me devices. On second start, I noticed that both the 'Phone' and 'Bluetooth' were grayed out in the Settings menu. After completing my drive, I shut off the car and then turned on Accessory mode, and Bluetooth seemed to be working again.
Now I'm concerned whether this is the start of a downward trend in the technology, but without an error condition there's not much use in taking it in to Lexus.
thomas1
Hybrid Technology
Jun 6, 2017 06:17 AM
DaCajun
Dec 7, 2007 03:48 PM
Booyah
Sep 13, 2007 03:30 PM
JohnAMG
GX - 1st Gen (2003-2009)
16
Mar 15, 2007 10:29 AM
