Offset help please.
Old Jun 7, 2014 | 04:37 PM
KB350's Avatar
KB350
Default Offset help please.
New to the forum and have a quick question that I couldn't seem to find in other threads. I just got a 2014 GS 350 F Sport RWD and am in the market for wheels and was wondering if this fitment would work (just got Tanabe springs so the car will be lowered):
20x9 +32 on 245/35/20
20x10 +45 on 275/30/20
Any feedback is greatly appreciated!
Old Jun 7, 2014 | 04:50 PM
SNiiP3R's Avatar
SNiiP3R
You won't have any problems. Just make sure the new rims clear your BBK's (front brake calipers).
Old Jun 7, 2014 | 06:19 PM
G-SharK's Avatar
G-SharK
KB350 - You should be good! Post some pics of your new shoes
Old Jun 7, 2014 | 10:25 PM
Dukeaudio's Avatar
Dukeaudio
They will fit but I think you'll have slightly more poke in the front than the the rear.
Old Jun 8, 2014 | 08:58 AM
KB350's Avatar
KB350
Thanks for the feedback. Duke, pardon my ignorance but what do you mean by "poke"?
Old Jun 8, 2014 | 01:16 PM
Dukeaudio's Avatar
Dukeaudio
For me, Poke is when the lip of wheel extends past the vehicle's body when viewed from above. When i measured for my set, 9" et32 was closer to being flush w/the body w/maybe 1-2mm poke. However 10" et45 was slightly tucked by about 3-5mm, something you may not even notice but I did. I want my wheels to have the same amount of poke. Worst case more rear poke but not more front. An et40 might be a better balanced fitment for a 10" wheel. Otherwise go 10.5" et45 to fill in the 3-5mm difference.
Old Jun 8, 2014 | 04:32 PM
KB350's Avatar
KB350
Thanks Duke. I will prob pass on this setup as I prefer a look where the wheels are more flush with the body. Any idea on what offsets will be ideal for that?
Old Jun 8, 2014 | 07:54 PM
Dukeaudio's Avatar
Dukeaudio
Going off my measurements, and what i've seen here, flush fitments are appx:
Front= 9" et37 or 9.5" et32
Rear= 10" et40 or 10.5" et45
These fitments should be flush give or take a few millimeters. How much do you plan on lowering your car?
Old Jun 9, 2014 | 03:29 AM
KB350's Avatar
KB350
I am lowering the car with Tanabe springs so nothing too drastic. Just want to make sure that I have no rubbing issues at all.
Old Jun 9, 2014 | 11:29 AM
G-SharK's Avatar
G-SharK
From my understanding, the rears will be fine. The front if you got with (Front= 9" et37 or 9.5" et32) it might not be correct. I believe if you go with a wider wheel like 9.5" et 32, you will poke out more than if you with 9" et 32. Check with all other wheel manufacture, Most will recommend front 9" et 32-37 and rear 10.5" et 45.
Best combo Is 9" et 32 or 30 and 10.5" et 45. My personal preference.
Old Jun 9, 2014 | 12:36 PM
LexFather
Guest
Posts: n/a
Those are two of the standard Vossen fitments that other companies have followed for the GS.
Old Jun 9, 2014 | 01:04 PM
Dukeaudio's Avatar
Dukeaudio
Good catch! I flipped the front offset numbers. I agree 9" et32 abd 10.5" et45 is a good fitment.
Old Jun 9, 2014 | 01:19 PM
G-SharK's Avatar
G-SharK
Anytime! Glad I can help, that's why I like this forum.
Old Jun 9, 2014 | 02:15 PM
Need4Speed's Avatar
Need4Speed
Former Sponsor
That fitment will work great on the GS no problems at all.
JEFFOS69
May 14, 2014 08:12 PM
DoomLight
Sep 20, 2011 05:06 AM
IcePick06
Wheels, Tires & Brakes Forum
May 27, 2010 01:04 PM
MORE4MY 4
Nov 13, 2008 11:42 AM
inrisls400
May 19, 2007 03:05 PM
