Remote Engine Starter (TIS / Techstream)
Old Feb 10, 2025 | 05:53 PM
bclexus's Avatar
bclexus
Originally Posted by SoloJenk
Yes, but I was able to find the installation instructions on another post. Attachment - ClubLexus - Lexus Forum Discussion - L-AI-0181-D PDF
@SoloJenk - Do you already have the Remote Engine Starter kit? I guess it includes one new Smart Key fob that replaces your two original Smart Key fobs, right?
What version of Techstream will you be using to set it up and program it to the ECUs?
Old Feb 10, 2025 | 06:14 PM
bclexus's Avatar
bclexus
@SoloJenk - Is this the Remote Engine Starter Kit you're installing?
Old Feb 11, 2025 | 03:58 AM
SoloJenk's Avatar
SoloJenk
10th Gear
@bclexus Yes. The kit I have does not include a new key fob. It integrates with the vehicle's existing key fob, so no need for an additional remote. Using Techstream v18.00.008
Old Feb 11, 2025 | 06:16 AM
bclexus's Avatar
bclexus
@SoloJenk - Thanks for the answer.
Have you begun the installation yet, and if so how far along are you with it?
Old Feb 11, 2025 | 10:38 AM
EAST's Avatar
EAST
I saw a reddit post a bit ago that mentioned that the remote start, even if key fob only, would still attempt to get authentication from Lexus. If that were the case, then the 3G models would not be able to. Then again I don't know if key fob remote start existed at one point without need an Enform account.
Old Feb 11, 2025 | 11:51 AM
bclexus's Avatar
bclexus
@EAST - I can't say for sure if this is all true, but a little bit of limited research (along with my own experience* ) indicates that for a Lexus Smart key fob to be able to remote start a Lexus vehicle the following must take place:
The Smart Key fob must be coded to the vehicle.
A trial or paid subscription to Lexus Enform is needed to use the Smart Key fob to remotely start the Lexus vehicle.
The Lexus vehicle must be compatible with Lexus Enform Remote Service, meaning it needs to be a 2015 or newer model.
The Lexus vehicle must have an active cellular network connection, capable of 4G/5G cellular communication. [This may be questionable.]
The Lexus vehicle must be within range of the Smart Key fob.
I believe to have a Lexus Enform account requires the vehicle be a 2018 or newer model with an activated/updated DCM (Telematics Communications Module).
* Note: I do not believe the Smart Key fobs for my 2018 GS 450h would remote start my car prior to having my car's DCM being activated/updated.
It's my awareness the Telematics DCM of pre-2018 Lexus models cannot be updated/activated to use today's 4G/5G communications.
[This may be questionable whether it is needed for Smart Key fob remote starting using the
Remote Engine Starter Kit - the topic of discussion in this thread.]
Lexus Service Bulletin
L-SB-0006-19 is in the attachment of this post.
File Type: pdf
Skotros
Feb 9, 2025 05:58 PM
deusex
RX - 4th Gen (2016-2022)
Feb 24, 2018 10:46 AM
SAID
Dec 31, 2016 12:57 PM
slver250
Jun 12, 2006 03:11 PM
dkaplan435
Mar 9, 2006 07:45 PM
