TPMS not reading on dash
On a normal drive, it must awaken instantly with no orange warning light just like the OEM TPMS sensors.
I would have used the OEM Toyota sensor ID's that I had already put in, but I had them removed and returned to me so I can use them in my Highlander. So I didn't want to have the same ID's in two different cars. I had purchased these OEM sensors to use in my Highlander. I had one installed and it worked fine. But then the Lexus needed a sensor replaced, and according to the listing of these sensors, they were supposed to work in the Lexus. So I installed the other three into the Lexus, and that's when the pressure display stopped working. So either the one sensor that was still in the car didn't work with the new sensors, or the new sensors just were not the right ones for the Lexus. Maybe if I had put the entire set of four in the Lexus, it might have worked.
I just got back from the tire shop. I purchased a full set of the Autel MX sensors, and had my tool auto generate new ID's for each one. Had them installed, and everything is working now. I did notice that it does seem to take a minute or even need to be moving before the pressures show up. I really debated on whether to go Denso or Autel. I found the Autels at Nappa for $29.95 each. So it was a much better deal.
F350
Sep 3, 2013 07:49 AM
