Electrical Shutdown
Old Sep 17, 2019 | 10:48 PM
DalCowbyz's Avatar
DalCowbyz
Default Electrical Shutdown
2006 GS 300, 90k miles. While driving the car tonight all of the lights and dash panels started flashing and power steering failed. Flashing continued for a minute or two until everything went dark, engine continued running. Turned off the car, waited a minute or two, then started the car. Everything okay for a minute and then it started all over again.
Is this the body control module (if this car has one), or something else?
Thanks, Clint
Old Sep 18, 2019 | 05:38 AM
Gotcha350's Avatar
Gotcha350
Have the charging system checked first. Make sure that the battery is fully charged before testing the alternator.
Old Sep 18, 2019 | 05:42 AM
ibidu1's Avatar
ibidu1
Sounds like maybe bad battery terminals, might want to remove and clean them. Also unbolt that nut on the terminal, and clean under it.
Old Sep 18, 2019 | 07:23 AM
TRD_Power's Avatar
TRD_Power
I'm going to go with a bad alternator on this one. Start easy with what ibidu1 suggested, but based off of my past experiences with alternators going out, this is pretty much what happened before they gave out completely.
Old Sep 18, 2019 | 03:25 PM
MX73's Avatar
MX73
Have the charging system check. I'm with everyone on the alternator going bad. Mine did the same but I also had an electrical burning smell from the engine compartment.
Old Sep 18, 2019 | 06:19 PM
DalCowbyz's Avatar
DalCowbyz
Thank you everyone for the rapid response.
Old Sep 25, 2019 | 08:39 PM
DalCowbyz's Avatar
DalCowbyz
got the new alternator installed. My helper got ahead of me and reattached the battery negative, which became evident when the alternator positive lead touched the valve cover. Now the only power I can see is the door and footwell lights, and the ignition switch backlight. I’m too old to get under the dash to check those fuses and the underhood fuse panel checks out. Help!
Old Sep 25, 2019 | 10:25 PM
ibidu1's Avatar
ibidu1
Sounds like you popped the main fuse, its called the fusible link
https://www.ebay.com/itm/FAST-EXPEDI...8AAOSw4oNal1V4
Old Sep 25, 2019 | 10:32 PM
DalCowbyz's Avatar
DalCowbyz
Is that the block on the left side of the fuse panel located in the engine compartment?
Old Sep 26, 2019 | 01:34 AM
ibidu1's Avatar
ibidu1
Correct, I would test it before ordering a new one
This may help you out
Thomp2
Dec 6, 2022 05:39 AM
LuT
Dec 26, 2018 11:38 AM
LuT
Dec 2, 2018 07:47 PM
SlammedGs3
Jan 22, 2018 09:09 AM
nawilliams
May 13, 2012 04:40 PM
