All warning lights on
Old Dec 1, 2018 | 12:12 PM
LuT's Avatar
LuT
Default All warning lights on
2009 Lexus IS 250 driving well, then turned into gas station when all warning lights turned on and lost power steering. Pumped gas but car would not start. Got a jump, car started right up, but when I put it into drive, the dash board started flashing on/off and all warning lights on. I was able to move it to a parking space directly in front of pump but without power steering. Had to have car towed. Any ideas on the problem?
Old Dec 2, 2018 | 04:23 PM
IS2Fuego's Avatar
IS2Fuego
Any updates on your situation? Did you get the codes pulled? Possible engine stall or alternator failed?
Old Dec 2, 2018 | 05:28 PM
kevin3344's Avatar
kevin3344
Does it crank but not turn over? If so, it could be your fuel pump. You didn't mention your mileage but we just replaced ours with 151k on the odometer.
Old Dec 2, 2018 | 06:14 PM
LuT's Avatar
LuT
I decided to install a new battery and it worked! Car runs fine. It has a strange hum when not in gear but other than that it runs great. I’m so glad!
Old Dec 3, 2018 | 10:44 AM
Gville350's Avatar
Gville350
Immediately get your alternator checked! Your car might be ok for a few days, then the battery will be fully drained due to a ill-functioning alternator. Alternators seem to be going out quite frequently on these models now a days. In fact, I've had mine replaced once already.
Old Dec 4, 2018 | 04:47 AM
Aspect's Avatar
Aspect
+1 with alternator! Exact things happened to me.
Old Dec 4, 2018 | 07:22 AM
Bichon's Avatar
Bichon
+2, check alternator. Loss of power steering is rarely (if ever) just a battery issue.
Old Dec 26, 2018 | 11:38 AM
jessycrazy's Avatar
jessycrazy
Default I want to know that
i want to know why those light are turning on. And I stop my car’s engine and start again those lights are turn off. Please help me. How to do?
LuT
Dec 2, 2018 07:47 PM
guesswh0
Oct 8, 2015 10:35 AM
MangoMan
Feb 11, 2014 06:46 AM
vltjr
Nov 15, 2006 04:38 PM
lorenzo816
Dec 30, 2004 01:38 PM
