GS transmission problems?
Old May 25, 2021 | 11:13 AM
  #121
PauloFR's Avatar
PauloFR
I think you should replace the filter and renew as much fluid as possible (4 to 5 drains & fills should do it) so consumables and fluids are eliminated.
My transmission has been serviced by Lexus at 167k km, and it made it smoother. Not that it wasn't before, I said "rough" in my previous post but it wasn't really rough, the only thing was sometimes when I accelerated and braked a lot in a short period of time, I felt the shift just a bit, but it wasn't shaking the whole car either. Now, it doesn't happen anymore. The transmission is buttery smooth and gear changes are quick.
I can even say that I think Aisin RWD transmissions are the best in class ex-aequo with ZF transmissions (a bit quicker but less reliable). Shift points are perfectly calibrated.
Now, regarding the downshift issue caused by the ECU, I don't know when it will happen and what are the probabilities. At least we are lucky that a company such as SIA exists so we can have it repaired without breaking the bank.
Old May 25, 2021 | 12:10 PM
  #122
Fms01's Avatar
Fms01
Thanks, I'll look up a DIY on the filter change and see if I want to do that too.
Old Jan 24, 2022 | 10:26 PM
  #123
808isf's Avatar
808isf
Originally Posted by yadadaHan
i think my 06' gs300's tranny is going out. check vsc light came on and car won't shift pass 3rd. tried a transmission fluid flush and same problem came back within 30 miles. has anybody else had this problem? it only has 94,288 miles!
I'm having thay same problem. My gs 300 won't shift into over drive kn freeways. Any one have a idea why ?
Old Jan 24, 2022 | 10:30 PM
  #124
808isf's Avatar
808isf
Old Jan 25, 2022 | 05:14 PM
  #125
11Es350Lex's Avatar
11Es350Lex
Default I do not know honestly
I wish I knew but sounds like you need a new trans maybe just sell the car and look for a 350?
Old Jan 26, 2022 | 03:19 AM
  #126
ibidu1's Avatar
ibidu1
Have you sent out the ecu to SIA electronics to have them inspect the transmission module thats inside the ecu? If not park the car and remove the ecu and mail it out to them. They are quick turn around, they charge like $110-140 for the service and you can search on google or ebay. But this is a common problem on the 2006 GS300 only, they have ecu issues, but good thing SIA can fix them. If that doesnt fix it, then take it to a mechanic and have him test all the transmission solenoids as thats another common issue but not as common as the ecu.
nickeltime
Jan 9, 2022 04:37 AM
friscogal
RX - 1st Gen (1999-2003)
Jan 23, 2010 03:33 PM
KevinGS
May 7, 2006 12:14 PM
big ken 456
GS - 1st Gen (1993-1997)
May 14, 2005 06:56 PM
