GS transmission problems?
Old Mar 14, 2019 | 11:10 AM
  #106
mike6697's Avatar
mike6697
Originally Posted by 703
The gs300 is one of the most unreliable Lexus around. It wasn’t sold for very long in the GS lineup.
thanks , it’s a GS350 2015 with CPO warranty so I’m taking it to the dealer ASAP
Old Mar 14, 2019 | 02:49 PM
  #107
Gotcha350's Avatar
Gotcha350
Originally Posted by mike6697
I recently purchased a 2015 GS 350 CPO and it cold start at over 1500 rpm then when shifting into D it jerks or jumps, is that normal?
If you are shifting from park to drive at 1500 RPMs then you will experience some movement. Let the RPMs come down some first...you must shift to drive before the car finishes its system check....geez...
Old May 11, 2020 | 11:43 PM
  #108
DSWininn's Avatar
DSWininn
At 147k my transmission started failing, & at around 149k I had to get the the transmission rebuilt. It's a 06 gs300
Old May 12, 2020 | 01:40 AM
  #109
FlashWhyte's Avatar
FlashWhyte
I think after conversion mine is approx 104k miles, does not skip a beat in the slightest.. all gravy
Old Jul 4, 2020 | 08:28 AM
  #110
Kennny1977's Avatar
Kennny1977
8th Gear
Would like to add that if your transmission ever has a problem or you get a shift solenoid code, if you disconnect the battery and it goes away, then it is your ECU causing the problem. The ECU also does not have to be replaced. It's normally a dry solder joint, so reflowing or baking the board will fix it.
Old Jul 4, 2020 | 09:42 PM
  #111
FlashWhyte's Avatar
FlashWhyte
Hey mate
This is interesting as I've recently experienced similiar problems. The car would hesitate at RPM < 1000 when taking off and throw the P2757 code (TCC solenoid stuck off or not functioning). Then, when in limp mode, would drive like a troll =[
Took it to a trans place and they flat out said new tranny (didn't even drop the pan).
But anytime I've cleared the code, the car drives like an absolute dream.
So tomorrow I will be getting a mate of mine to clear the codes once again and using this as an experiment.
Hypothesis is: If it runs like a dream, it's not the trans. It must be electrical. What that electrical part is though I have no idea.
Based on this post, it seems like a good start is to look at the ECU?
Are these things we can get repaired or is it best to replace them??? I feel like I'm really close to fixing this issue now and would love further info to learn
Old Jul 5, 2020 | 01:03 AM
  #112
ibidu1's Avatar
ibidu1
Originally Posted by FlashWhyte
Hey mate
Is this a 2006 GS300, because majority of ecu issues are 2006's. Send it out to have it inspected and fixed if need be, only $110 for the service
Old Jul 5, 2020 | 01:08 AM
  #113
FlashWhyte's Avatar
FlashWhyte
yep, it certainly is a 2006..
my trans experiences no issues when cruising highways etc and has no slippage between gears like some others have had to deal with.
It could be a combo of both solenoid and ecu.. but the way it improves when we clear the code is leading us to believe its Predominantly electrical
when you say “send it out” - what type of business would I be sending it to? are you referring to auto elec or dealership or?
thanks so much in advance
Old Jul 5, 2020 | 01:14 AM
  #114
ibidu1's Avatar
ibidu1
SIA electronics, also after you send it for inspect. Best to do a drain and fill the transmission, if you havent done this. Solenoids are known to go bad in the 2006's, but not common. So its best to get the trans fluid drained and filled 2 to 3 times atleast.
https://www.ebay.com/itm/Lexus-GS300...d8ac62bbc2b076
Old Jul 5, 2020 | 07:09 AM
  #115
Kennny1977's Avatar
Kennny1977
8th Gear
There will be lots of transmissions replaced or rebuilt when it's really the ECU. I had a shift solenoid code and CEL and clunking into reverse, I took it to a transmission specialist and he it was most likely the ECU, could have bull****ted and said he rebuilt my transmission and just fixed the ECU but he didn't. Sure enough it was the ECU, it was rebuilt and I didn't have that problem again.
Old Jul 5, 2020 | 08:56 PM
  #116
PauloFR's Avatar
PauloFR
I have no problems with my 06's transmission, excepts some slightly rough shiftings. It has 151k km, which isn't much, but as the previous owner told me he never thought about replacing the ATF, I think it is because of its age. I'm planning to do 3 or 4 drains and fills.
Old May 14, 2021 | 06:24 PM
  #117
11Es350Lex's Avatar
11Es350Lex
Default 2011 gs350
103k some annoying feeling shifts 1-2 but mostly alright want a trans flush but scared.
Old May 14, 2021 | 07:30 PM
  #118
gs350fan's Avatar
gs350fan
No reason to flush. You can dump the fluid and if you want change the filter.
Old May 15, 2021 | 05:31 AM
  #119
ibidu1's Avatar
ibidu1
I would do just a drain and fill at first, drain then measure and refill the same amount and a bit more for pump fluid loss
Old May 25, 2021 | 09:53 AM
  #120
Fms01's Avatar
Fms01
I have an 07 GS350 AWD that occasionally on light load (eg going up a slight incline) will send a shudder through the car, backing off or accelerating will stop it. I think I'm going to do a fluid drain and fill this weekend and see how that goes unless anyone else has other thoughts.
Cheers.
Julian
