Alignment everytime you switch wheels?
Old Oct 30, 2011 | 11:05 AM
gridlock13's Avatar
gridlock13
Default Alignment everytime you switch wheels?
is it necessary to get an alignment done whenever you switch between your summer and winter wheel set up? sorry if this is a noob question. this is the first time i've ever gotten rims and i'm still learning.
to moderators, if this is in the wrong section i apologize.
Old Oct 30, 2011 | 11:46 AM
bigblack06's Avatar
bigblack06
Usually its just to help your alignment if its out, I believe its not required its more a precaution than anything but correct if I'm wrong.
Old Oct 30, 2011 | 02:11 PM
lkapimp216's Avatar
lkapimp216
No you shouldn t need to align the vehicle to switch wheels usually tire companies recommend it, how do the tires look? are they wearing even?
Old Oct 30, 2011 | 02:12 PM
PHML's Avatar
PHML
Master Thread Closer!!
Not necessary to get alignment when switching from summer and winter wheels.
Old Oct 30, 2011 | 03:41 PM
gridlock13's Avatar
gridlock13
thanks guys. the tires look perfectly fine. i've only had the works on for 3145 miles (about 2 months) so i probably wouldn't see much tire wear anyway.
Old Oct 30, 2011 | 03:42 PM
rominl's Avatar
rominl
exclusive matchup
i do alignment when i lower the car or so, not when i change wheels
Old Oct 30, 2011 | 07:39 PM
sbui's Avatar
sbui
what about if you go from 17's to 18's do u need do it then?
Old Oct 30, 2011 | 08:15 PM
BinaryJay's Avatar
BinaryJay
Not unless you're putting the wrong size tires on. A 16 inch wheel and an 18 inch wheel with the right tires will the same as far as the car is concerned.
Old Oct 31, 2011 | 04:05 AM
IXI187IXI's Avatar
IXI187IXI
they only time you need to get your car aligned is if you remove a major suspension part and reinstall. changing wheels, tires, etc... will not require an alignment
Old Oct 31, 2011 | 05:20 AM
sbui's Avatar
sbui
Kool thanks guys
mexguy89
Mar 18, 2013 07:29 AM
platinumac
May 15, 2008 09:06 AM
D-MAN63
Suspension and Brakes
Feb 4, 2003 05:47 PM
