Nav Help
Old Sep 6, 2007 | 07:15 AM
ted5469's Avatar
ted5469
Default Nav Help
I put in my work address and it leaves me down the block. How do i adjust this so it leaves me infront of my office.
07' GS350 AWD W/ MARK and NAVI
Old Sep 6, 2007 | 09:07 AM
Yang1815's Avatar
Yang1815
Instead of address, try a phone number or just "current position" when you're in front of your office.
Old Sep 6, 2007 | 09:09 AM
Jace7's Avatar
Jace7
it's probably just grouping the buildings address or something similar and taking you as close as it can without being too wrong.
You could drive right in front of the building, set that specific spot as a saved destination, then it will hopefully take you back to that spot at later dates.
Old Sep 6, 2007 | 09:28 AM
oldcajun's Avatar
oldcajun
My manual says that the NAV will announce that "You have arrived at your destination" just prior to arrival so that you can find a parking spot or lot entrance that is not mapped.
Steve
Old Sep 7, 2007 | 09:28 AM
larrs's Avatar
larrs
I don't know of any navigation system, OEM or aftermarket, that can pinpoint the exact location of a house/building number. Typically the map data gets you to a block or segment of the road and then you have to find the number yourself.
When I am parked in my driveway, the navi reports my location as the number of the house that's two houses down from mine.
As Jace7 suggests, use the MARK button to save the location of your office, then you can navigate to that exact location in the future.
HTH
Old Sep 7, 2007 | 01:59 PM
Cut-Throat's Avatar
Cut-Throat
Veteran: Navy
It is probably the DVD software, rather than the Nav Unit itself. I would expect future releases to be more accurate with existing addresses, and then give you another problem that will be such a big headache that you'll forget the reason why you wanted to upgrade.
And yes, I was in the software business.
Old Sep 7, 2007 | 05:51 PM
alwayzspeedin's Avatar
alwayzspeedin
you can fix that you have to go in to settings a reposition your navi position.
Old Sep 7, 2007 | 06:12 PM
socalJD's Avatar
socalJD
Slightly different topic, do all 2007+ GS have the gen V nav ?
I heard that the 2006 GS still had gen IV nav units . . .
Old Sep 8, 2007 | 06:07 AM
larrs's Avatar
larrs
It's the underlying map data. Address number locations are not exact, the data is for a range of address numbers.
DAVEB1980
Sep 30, 2016 04:53 AM
athiker
NX - 1st Gen (2015-2021)
Mar 17, 2015 07:01 AM
nylawyer
RC - 1st Gen (2015-present)
Dec 5, 2014 03:04 PM
bca51192
Oct 21, 2014 09:15 PM
randomact
Feb 27, 2007 07:19 PM
