GS300 Help - Locking doors when driving off
Thanks (from a 1st time Lexus owner)
the manual has a lot of info. there is an entire chapter on door locks and key functions. Pgs 7-42 to be exact.
For the speed function (lock at 12mph instead of when shifting out of P), this is on Pg 38. The trick is, you have to CANCEL the shifting out of P in addition to SETTING the 12mph locking. In simpler terms, do this:
1. get in your car and close door
2. press start button twice, WITHOUT foot on brake pedal
3. press and hold LOCK on your door panel
4. count 1-one thousand, 2-one thousand, 3-one thousand, 4-one thousand, 5-one thousand
5. release immediately after 5-one thousand, doors will lock/unlock to confirm
6. turn off your car completely (press start button once without foot on pedal)
Then set for 12mph lock:
7. press start button twice, WITHOUT foot on brake pedal
8. put your foot on brake, and shift into N eutral
9. press and hold LOCK on your door panel
10. count 1-one thousand, 2-one thousand, 3-one thousand, 4-one thousand, 5-one thousand
11. release immediately after 5-one thousand, doors will lock/unlock to confirm
good luck
good luck
So this is a way to program c-best without Lexus techs?
good luck
hmm... it didn't work on my gs300. are you sure thats all?
I followed the procedure just as lexuslover and the manual explained. I want to add that the procedure should be done quickly in one fluid motion. Don't pause after depressing the start button. Although I didn't see it in the manual, I found I had to first cancel the old method before setting the lock at 12mph, just as lexuslover said. It took several tries, but just about when I was going to give up, I hit the magic sequence properly and it worked fine.
when i got home i read the manual and figured it out.
also, they got rid of the former complimentary 1k service for the "LPS" settings, but it sucks to have to make an appt and drive all the way to the dealership to have them do what you can do yourself (unless you want to change some of the other LPS settings that require their help). the best thing would be to have the salespeople get your preferences before delivery so they can set it up to your liking once you leave.
