ac light blinks
Old Nov 4, 2017 | 04:43 PM
swfl's Avatar
swfl
Default ac light blinks
I have a 2001 GS300. I just replaced the ac compressor and the condenser. When I was charging the system, the compressor came on once and the clutch didnt engage again. I looked at the dash and the ac light was blinking. There are stored codes, 21,24,41 and 43. My blend doors do not work, thats a job for another day. If i push the ac button, I can feel ice cold air come out for a second till the light flashes. Any suggestions?
Old Nov 4, 2017 | 04:52 PM
- V -'s Avatar
- V -
wrong forum boo
an admin will move your thread to the right section or, if you dont want to wait, you can repost this in the GS forums and edit your original post asking an admin to delete it.
good luck!
Old Nov 5, 2017 | 07:42 AM
swfl's Avatar
swfl
Old Nov 5, 2017 | 07:46 AM
swfl's Avatar
swfl
Old Nov 5, 2017 | 08:10 AM
kevin3344's Avatar
kevin3344
Check your relay...
https://www.clublexus.com/forums/es-...working-2.html
Old Nov 7, 2017 | 08:55 AM
bilgen's Avatar
bilgen
You need to be monitoring the gauge readings (high and low) while the compressor is coming on for whatever amount of time. You could have too much oil in the system (or not enough) causing the high side to "sky rocket," activating the high pressure cut out switch. Idk what those codes you provided mean. GL
Old Nov 11, 2017 | 11:08 AM
swfl's Avatar
swfl
The codes were pulled from the a/c control unit. I replaced the a/c relay and the compressor still shuts off right away. The compressor is a brand new Denso compressor and came with oil in it. I'll hook up the gauges again to see what readings I have. Thank for the info!
Old Nov 15, 2017 | 06:44 PM
dropthatta's Avatar
dropthatta
Did you pull a good hard vacuum on the system after replacing your compressor? Did you replace your dryer as well?
cgreenberg
Apr 23, 2024 07:11 AM
dumdumgreg
Aug 17, 2005 07:32 PM
D.K.
Maintenance
Jul 28, 2004 02:02 PM
blkstealthpaid4
Mar 21, 2002 07:51 AM
