Steering wheel telescoping issues
Old Jan 26, 2013 | 03:56 AM
hatteroo's Avatar
hatteroo
Question Steering wheel telescoping issues
Hey guys I have a 98 Aristo and just recently started to having issues with the my steering column. It's able to move up and down just fine, but it won't extend towards myself at all at times. It has only happened twice so far and some how later in the day or next day it works just fine. When pressing on the button to extend the column I can hear the solenoid clicking so I know it's getting power, but that's it. Anyone have an idea maybe?
It doesn't make sense to me that the gears would be messed up since it intermittently works. Thanks!
Old Jan 26, 2013 | 07:41 PM
Mr Jokster's Avatar
Mr Jokster
One tooth missing from a gear can cause a mess. What happens to a zipper when only ONE tooth is missing?
a mess
could be a couple missing or even just that one and the times it doesnt work its just sliding over that area, after a it slides, it finally catches the gear and begins to work again until it gets back to the open piece.
just my hypothesis.
Old Jan 27, 2013 | 12:53 AM
hatteroo's Avatar
hatteroo
a mess
just my hypothesis.
Thanks for the suggestion, but I don't think it's that since it doesn't appear to give a "slipping motion" since I hear the solenoid clicking or seems to be a solenoid anyways. It works as advertised right now though. Kinda weird
Old Jan 27, 2013 | 05:56 AM
1aristo's Avatar
1aristo
As a new member i can tell you there are LOTS of info floating around here concerning this.
Seems to be a common problem with dust build up in the motor as it is a sealed unit, so might be as simple as opening up and servicing.
Old Jan 27, 2013 | 06:52 AM
chicov8's Avatar
chicov8
you may find more info in ls400 forum that was common problem with ls400
Old Jan 27, 2013 | 09:54 AM
sivikvtec's Avatar
sivikvtec
Search!
https://www.clublexus.com/forums/gs-...heel-tilt.html
Personally, my height adjustment motor was not working when it was cold outside. I just moved it to the desired position one warm day and unplugged it. I will do the cleaning/grease fix one day...maybe...
Old Jan 29, 2013 | 01:53 AM
lextout's Avatar
lextout
disconnet the battery overnight and see if it works again, i did it to mine and it work miraculously.
Old Jan 29, 2013 | 05:13 AM
hatteroo's Avatar
hatteroo
Originally Posted by sivikvtec
Search!
Thanks guys!
Old Jan 29, 2013 | 08:31 AM
wbmx1981's Avatar
wbmx1981
I fixed mine. You need to remove the shell around the steering column. There is a motor that controls the adjustment function. Mine was dirty inside and the copper contacts were not touching causing the problem youre having. It's very easy. Google images of your make and model tilt motor, so you can see what youre looking for. I used compressed air and alcohol and q tips to clean it. Now its working silky smooth. hope this helps.
duballstar
12
Mar 6, 2013 01:01 PM
Farbound
Aug 30, 2012 03:59 PM
OKSTANCE
Maintenance
May 29, 2012 07:23 AM
charris
Dec 15, 2010 04:29 PM
rcftx
Jun 13, 2003 10:47 PM
