Curious
Old Dec 31, 2008 | 09:51 PM
smuv gs3's Avatar
smuv gs3
Default Curious
Now that I'm going FI ,I was wondering if I leave my ect trans switch set on power what affect would it have on a boosted gs?
Old Dec 31, 2008 | 09:59 PM
fordsvtmfl's Avatar
fordsvtmfl
i was wondering that as well...if i knew what it was that the power button actually did...(i know what it does...but how it does it) then i could probably figure it out...
Old Dec 31, 2008 | 10:04 PM
jcat_350's Avatar
jcat_350
you may notice some slight difference. All ECT PWR does is adjust the shift points higher in the rev range. That being said, you will be more likely to see max HP and Torque before a gear change if you're in PWR mode, since the trans waits a bit longer to shift.
Old Dec 31, 2008 | 10:24 PM
mtparker18's Avatar
mtparker18
It doesn't really do much. the only time i'd turn it on is on the track and the dyno
Old Dec 31, 2008 | 10:44 PM
fordsvtmfl's Avatar
fordsvtmfl
I have noticed that if the pwr button is on....and you floor it..it shifts at/about at red line...but it does the same thing if you floor it w/out it on...so I dont really bother with it.
Old Jan 1, 2009 | 07:23 AM
ROPADOPA's Avatar
ROPADOPA
ECT = electronic controlled transmission . it locks the torque converter up earlier. with out it on it slips the converter more for better gas millage.
If you want to try to feel it get cruising at 45-55 mph and after a while with it off hit the button you will feel it lock or hear the difference in tone of motor.
Old Jan 1, 2009 | 04:14 PM
AZDesertGS's Avatar
AZDesertGS
Originally Posted by ROPADOPA
ECT + electronic controlled transmission . it locks the torque converter up earlier. with out it on it slips the converter more for better gas milage.
Might want to check your resources on that one.....A torque converter is a mechanical device and can't be changed to a different setting by simply clicking a button. It does not lock it up earlier....lol
ECT PWR button simply changes the shift points.......that is all folks
Old Jan 1, 2009 | 04:21 PM
jcat_350's Avatar
jcat_350
+1 i was just about to say that. The ECT function strictly controls the TCM or trans control module...i.e. where the trans shifts in the rev range.
i think you pulled that torque converter thing outta your *** to be honest...
Old Jan 2, 2009 | 07:53 AM
ROPADOPA's Avatar
ROPADOPA
Read up, and know what your talking about before you bust out the wise *** comments, as that will get you nowhere?
http://www.autoshop101.com/forms/h16.pdf
Old Jan 2, 2009 | 08:10 AM
Debonair's Avatar
Debonair
/\ I remember reading a Toyota article similar to that a while ago but did not remember enough to chime in on it. Good info.
I also need to add that "Curious" is the worst thread title ever.
Old Jan 2, 2009 | 08:11 AM
Mr.412's Avatar
Mr.412
hahahahahahaha.... I love that button BTW
Old Jan 2, 2009 | 08:38 AM
muhbuhtuh's Avatar
muhbuhtuh
CL Folding 25,000
but i really thought i got more power if i switched it on...
Old Jan 3, 2009 | 06:50 PM
smuv gs3's Avatar
smuv gs3
Yeah that maybe the case but not only did it make you look you even posted as well LOL!!!!!! Any way thanks guys for commenting
S to the K
Aug 2, 2010 11:33 AM
John007
Jan 4, 2008 03:50 PM
Wald GS
GS - 1st Gen (1993-1997)
26
Jun 10, 2007 01:20 PM
Boodies
IS - 1st Gen (2001-2005)
Jun 28, 2001 12:24 PM
clivej
May 23, 2001 12:47 PM
