Speedo Calculation Question
Old Aug 8, 2007 | 11:09 AM
rz_racer's Avatar
rz_racer
Default Speedo Calculation Question
I know I saw a thread with the formula for this, but if you guys could help me out that would be great.
I have 2000 GS300 w/ an LMS SuperCharger
the OEM rear diff is a 3.96..
I am running a 285/30/19 tire in the rear AND a KAAZ 4.27 2-way LSD (w/WPC plates, which I love because there is no more chatter noise at low speed)
anyways,
when I am on the freeway and my speedo says 80mph, am I actually going faster or slower than what I see?
THEN
I am looking to go to a 285/35/19, will that make my speedo error worse or better?
Thanks in advance for all your help.
Airek
Old Aug 8, 2007 | 11:41 AM
rominl's Avatar
rominl
exclusive matchup
the 285/30/19 pretty much has the same overall diameter as stock. so when it says 80mph, that's pretty much your speed
if you put 285/35/19, overall diameter larger. it will have more error. if it says 80mph, you probably around 84mph
the rear gearing shouldn't have any effect on speedo. it has no effect on the 400/430, i don't think it will have any on the 300. speed sensor is close to the wheel axle i believe
Old Aug 8, 2007 | 12:12 PM
GS FONZy's Avatar
GS FONZy
i have checked with two diffrent nav units and it only shows a diffrence of about 3 mph and i have 20s with 255s.
Old Aug 8, 2007 | 02:19 PM
gs-ireland's Avatar
gs-ireland
Here is a site the explains EVERTHING you could ever need on wheels/tyres/offsets etc etc:
http://www.carbibles.com/tyre_bible.html
(Wheel sizes are on page 2)
Old Aug 8, 2007 | 05:19 PM
mikevanle's Avatar
mikevanle
Isn't the speedo calculated off the front wheels's speed sensors anyways? So it's independent of the diff ratio and the tire sizes.
Old Aug 8, 2007 | 05:48 PM
rominl's Avatar
rominl
exclusive matchup
independent of diff ratio, yes. tire sizes, no..... with different sizes, distance traveled per revolution is different. speed sensor is just checking on the axle/wheel revolutions.
Old Aug 8, 2007 | 06:27 PM
mikevanle's Avatar
mikevanle
Well the size mentioned was 285/295 so I reckon it was for the rears, which shouldn't affect the fronts where the sensor is at, no? Oh wells, whatevers...
[/proceed]
Old Aug 8, 2007 | 10:10 PM
rominl's Avatar
rominl
exclusive matchup
umm, good question. i was under the impression the sensor is in the rear, but now you mention, i can't be 100% sure
Old Aug 9, 2007 | 06:40 AM
GSoup's Avatar
GSoup
CL Folding 10,000
this is the calculator i've used in the past...
http://www.miata.net/garage/tirecalc.html
NotLucas
Apr 24, 2025 10:05 AM
nMeOnE
Jul 12, 2010 10:31 PM
TwentyTen
Wheels, Tires & Brakes Forum
Aug 13, 2004 05:04 AM
TXSTYLE
Oct 27, 2001 10:03 AM
