Start up screen while driving?
Old Oct 3, 2018 | 03:29 AM
Albo's Avatar
Albo
Default Start up screen while driving?
So for the first time the other day I'm driving and all of a sudden my GPS and radio shut off and my infotainment system restarts. No other check lights go on or anything else from what I recall. It resets. The Lexus enform screen pops up and boom right back to my gps and radio. Anyone had this happen to them before?
Old Oct 3, 2018 | 03:39 AM
mcmike522's Avatar
mcmike522
10th Gear
I've had my ES350 for a few months now and have never had a reset on the infotainment system. My guess is that the module had a memory leak or something else in the software caused the microprocessor to lock up. Kind of like having to reboot Windows when it locks up, except our module probably has a watchdog timer that monitors for software lockups and automatically reboots the module when it detects a lock-up. Next time you are in for service you can ask if they have any software updates for the infotainment system.
Old Oct 3, 2018 | 05:27 AM
Steve19067's Avatar
Steve19067
Although I never noticed this with my car, yesterday when I took it in for maintenance the tech reported that it happened while he was test driving the car. He performed a software update which he said was out this past June. So you might want to check into that. My car is a ‘15 ES350 without nav.
Old Oct 3, 2018 | 05:43 AM
lesz's Avatar
lesz
I bought my 2017 ES in November of 2016. A day or two after I bought the car, the system re-booted, and the same thing happened 2 or 3 weeks later. But it has not happened at all in the almost 2 years since then.
If it was happening on regular basis, I would be concerned, but with it only having happened a couple of times in almost 2 years, I'm not inclined to be worried about it.
Something that has also happened with the infotainment system on my ES about a half dozen times is that, when I've navigated to the phone screen to check my call history, contacts, or emails, the screen has frozen. When that has happened, after about a minute or two, the screen has unfrozen (without the system rebooting). I've found this behavior to be a bit more annoying because, during the minute or two while the screen is frozen, I'm completely locked out of being able to use the phone, apps, map, etc. Again, though, since this has happened only a handful of times in almost 2 years of ownership, I haven't been especially concerned.
Old Oct 3, 2018 | 03:14 PM
Albo's Avatar
Albo
Mine is a 2015 es350 with nav, but yea 6 months of ownership and nothing like this. It was so weird but doesnt seem serious. If it happens again, I'll update.
Old Oct 3, 2018 | 05:40 PM
mcmike522's Avatar
mcmike522
10th Gear
I agree it is annoying when computerized systems don't respond because they are doings tasks that can probably get done in the background.
Not sure how Lexus wrote their code, but maybe the system is set to suspend usage of the infotainment system while the system downloads a ton of information from your phone. I guess you could try a phone with only a couple contacts and a couple entries for call history and only a couple songs and see if that is the case. There is also the chance it is the phone's software fault that communications are locking up. I seriously doubt a Lexus dealer would have a Bluetooth sniffer tool necessary to monitor the phone/car communications and figure out what is the cause of your lockups.
Old Oct 4, 2018 | 11:03 AM
jamestpc's Avatar
jamestpc
my 17 did that for a bit too.
probably about 4 times max in a year.
Old May 13, 2024 | 06:34 PM
scottp461's Avatar
scottp461
7th Gear
My 2017 ES 300h was seriously heat damaged by being too close to a fully engulfed vehicle while parked (it was 10 day old!)
It was in the body shop for 4 months. During the drive home (after being repaired) the infotainment system rebooted once; it never happened again. Assumed that it sat unused for too long and needed to resynchronize or something.
Cut to a couple of weeks ago. Waiting in line at a drive thru it just rebooted. Took just a few seconds, then back to normal; nothing since. As mentioned by others, won’t be concerned unless it becomes a thing!
Old Aug 3, 2024 | 05:51 PM
bklynlex71's Avatar
bklynlex71
ive had this happen to my 2018 es350. at one point it was resetting non stop.. so they updated the software for the navigation. that fixed it. it does however randomly freeze or reset once in a while when driving out of no where. you can also try to reset it yourself by holding in the power button 10 seconds to see if anything changes or if it freezes
CrazyChino
NX - 1st Gen (2015-2021)
13
Jul 19, 2023 02:44 AM
TruPlaya26
RC F (2015-present)
56
May 15, 2017 05:23 PM
CAWjr
GX - 2nd Gen (2010-2023)
40
Jun 11, 2016 03:33 PM
andyville
Jun 9, 2016 04:34 AM
ggzoa
Mar 10, 2006 12:41 PM
