Build Threads Details on Club Lexus LS430 owner vehicles
YannG's 05 Lexus LS430 Build thread
Old Mar 7, 2025 | 06:02 AM
  #331
70Chevelle's Avatar
70Chevelle
Originally Posted by YannG
Hey 70chevelle
Honestly I don't remember - the image below shows what I used but I dont remember the exact part number. Maybe try: Part # 961-034D
Thank you, I appreciate it.
This thread is a huge help with many things I'm planning to do with the car.
Old Mar 8, 2025 | 06:21 AM
  #332
YannG's Avatar
YannG
you're welcome - always happy to help
feel free to reach out if you have any questions about fitting the kit!
Old Mar 22, 2025 | 01:50 PM
  #333
70Chevelle's Avatar
70Chevelle
I just wanted to say THANK YOU for posting all this information. Thanks to your pictures and info, it was a breeze to install front and sides. Bought only 1 roll of gasket so I couldn't finish the rear, about to tackle that this weekend. Lowering and wheels next.
Old Mar 22, 2025 | 03:38 PM
  #334
funcrusher's Avatar
funcrusher
I need to read this thread and come up with a check list of things I need to put the Celsior lip kit on
Old Mar 28, 2025 | 05:39 PM
  #335
YannG's Avatar
YannG
@70Chevelle - Glad to hear the info and pics helped! Excited to see how it all comes together—lowering and wheels are going to take it to the next level! Keep us posted!
@funcrusher - Do it - get that celsior kit on !
Old Apr 3, 2025 | 03:14 AM
  #336
Holden53's Avatar
Holden53
Hello all,
Quick update - I decided to replace my telescopic steering wheel motor as it started to fail about a month ago ( faint sound when moving the steering wheel in and out) and eventually it completely failed 3 weeks ago. Not wanting to spend over $300 for a new motor I search online for a used one. I actually found a brand new/unopened motor on the Facebook market place. Long story short I paid $60 for a brand new/un-opened telescopic motor that works perfectly! I was super happy
Parcel arrived in a genuine Toyota box.
To my surprise, the motor was in a fully sealed plastic bag prooving it was brand new.
Steps to Replace the motor can also be found in this DIY Guide: (https://www.clublexus.com/forums/ls-...-write-up.html)
Remove the 2 screws on the lower panel under the steering wheel/knee airbag.
Un-plug all of the connectors:
Wiggle yourself in the footwell and locate the motor - Remove the two 10mm bolts:
(old motor vs new motor) - Same part number !
Turns out my LS had the Steering column TSIB ST00104 Universal Joint assembly fitted to it by the previous owner:
Bolt down the motor and plug it back in, install the connectors and screw the lower panel back in place. Turn the ignition on and test the wheel by making it go in and out! Mine now works perfectly
Considering my LS is nearly at 200k she does have quite a few stone chips on the bonnet. I saw this cool detailing video on youtube where the guy used a Cornell paint pen so thought I would give it a go.
Purchased some OEM touch up paint and lacquer.
Clearly visible stone chips:
The paint pen in action:
The end result:
I am really pleased with the result! I will need to add one more coat and then the pearlescent clear coat.
As always all comments welcomed
Thanks,
Yann
Late to the party - but thanks for going through this regarding the adjustable steering wheel motor and removal of the lower panel. BTW great job overall on your project car and nice use of the well pen to correct the paint chips.
Old May 13, 2025 | 01:15 PM
  #337
YannG's Avatar
YannG
Thanks @Holden53 - I appreciate the kind words
Old May 13, 2025 | 09:32 PM
  #338
funcrusher's Avatar
funcrusher
Yann, how noticeable is the color difference between your lip kit/other painted mods and the factory paint?
Old Jun 20, 2025 | 12:34 PM
  #339
YannG's Avatar
YannG
I got really lucky — it's almost a perfect match. I didn’t want to repaint it since it wouldn’t match the weathered look as well.
Old Jul 10, 2025 | 12:42 PM
  #340
YannG's Avatar
YannG
Default Timing belt / Waterpump + Cam seals
Hello Clublexus
Big news — I recently accepted a new position as an SAP Product Owner at Toyota Motors North America! They offered an amazing relocation package, so we’re moving to Dallas, Texas. We’ve already found a home and will be officially leaving Atlanta on July 25th.
Before the move, I figured I’d get the car checked out by Dan at The Auto Lounge — turns out the cam seals on the passenger side were starting to leak. What was supposed to be a simple inspection ended up costing me a small fortune. But since Dan's the only one I trust with the car, I decided to go all-in with the classic "while you're in there" approach.
We ended up doing a full timing belt and water pump replacement, along with new cam seals. Since I had recently changed the spark plugs and valve cover gasket, there was no need to redo those. Dan also replaced a bunch of vacuum lines that broke during the process (one EVAP, two PCV, and two lines that go to the power steering advance valve). It was a big job, but now that it’s done, the car should keep running strong.
I’ve been toying with the idea of selling it — maybe getting an LX470 or a Land Cruiser — but for now, I’m keeping the LS. I might put it up for sale in Dallas. Either way, I wanted to make sure the next owner (or myself) wouldn’t have to worry about any major work, so I got it all taken care of. The car feels great, and Dan did an excellent job!
The car at Dan's shop ready for open heart surgery:
Pictures of the cam seal oil leak:
Some pictures Dan took:
The inside of the engine looked good for 220k - no sludge
New parts:
Note: The bright metal line is where the hard seal was starting to wear the gear - so its a good thing that we replaced them.
All done and ready to be picked up:
Mandatory wash:
I’ll be doing one last Buc-ee’s run with the Atlanta LS guys before the move — gonna miss this crew. If anyone’s in the Dallas area, I’d love to meet some fellow car folks out there!
Yann
Old Jul 11, 2025 | 07:20 AM
  #341
Thirteenthcor's Avatar
Thirteenthcor
Hello All,
Another quick update - I attempted to work on the car this weekend, however ran into a very "unfortunate" issue, let me explain:
Saturday :
The plan was to finally fit the Air Lift Performance suspension struts, but as I attempted to take off the driver side front wheel this happened:
The locking wheel nut and key both broke! Funnily enough, I had good year refit/seal that exact tire about a month ago, perhaps they way overtightened the wheel and therefore left me stranded and unable to continue working on the car...(remember this is my daily...)
I took the car to Goodyear, but they were unable to help me and said I should go to the dealer. Fast forward 45mins/1hr I end up at Roswell Lexus, I explain the situtation and was told to wait in the lounge until further notice. After a 1hr30 a Lexus representative comes up to me saying they will need to drill the shattered locking wheel nut and the stud itself.
I was told to come back at the end of the day and took the complimentary rental car for the afternoon, granted it wasnt a newer LS or the LC it was still relatively fun to drive something very different to the LS.
The NX was fine, not much feedback in the steering wheel, power was dull...overall not a car I would buy, but fun to drive for free!
I went back to Lexus at 4:30 and picked up the car after asking them to do an oil change (they had a deal going on for less than $40), do my emissions along with a free complimentary car wash. I basically ended up doing no work at all on the car, spending most of my day at the Lexus Dealership and having to pay way too much money to have a stud/locking wheel nut drilled out + new stud fitted.
Sunday :
I decided to work on other things that needed to be done to the car, started off by removing the rear seats to access the sub:
unbolted the sub from the car:
As you can clearly see the sub had seen better days...
I bought re-foaming kit online and decided to give it a go:
I also decided to clean the SMOG sensor as I dont think it had ever been looked at.
As i thought, it was very dirty:
I cleaned the filter and casing the best I could and refit it:
Last but not least, a couple pictures of her and clean and waxed...
As always, all comments welcomed
Thanks,
Yann
Lexus dealers do not regularly stock synthetic 5w30 even though they list a part number for it, and will instead install conventional 5w30 with a YZZD3 filter.
I would not continue to have my oil changes done at the dealer.
Old Jul 11, 2025 | 10:29 AM
  #342
kos's Avatar
kos
Hello Clublexus
Yann
Congrats on the new gig! Car is looking great as always.
Old Jul 11, 2025 | 02:00 PM
  #343
YannG's Avatar
YannG
I've only taken it to the dealer for an oil change once—I've done all the others myself regularly since then.
Thanks Kos, Appreciate it
Old Jul 20, 2025 | 09:08 PM
  #344
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
Congratulations on the new job! I don’t live in Texas anymore but do live in Oklahoma City now and occasionally come to Dallas. There is a lot of guy on here from the Dallas area.
I always wanted to go work at Toyota corporate. I hear it’s a great place to work.
