Question for BBK owners. Do you lose the e-brake?
As the title suggests. I might be picking up a set of StopTech or Rotoras for all 4 corners soon. Just wondering if I will lose the e-brake. I always step on it when I park on an incline. Hopefully I won't have to lose it, but I think I might because the stock setup is a drum in disc. The BBK seem like they're disc only.
Someone chime in?
Someone chime in?
Forum Administrator
I'm guessing you need one of the four corners BBK guys to chip in. I've only got the 355mm Brembo's up front, OEM (upgraded rotors, lines, pad, fluid) in rear. My parking brake works fine.
The One
Originally Posted by JeffTsai
Teelex, thanks for the info. However, anyone know abuot the Stoptechs? The rear hats look like there is no "inner drum" for the stock e-brake.
Originally Posted by rominl
huh?! this is stoptech 4 corners, it's different rotors?
For any upgraded brakes it would be outright silly if a vendor made the inner rotor size anything different from stock innner rear rotor size. Meaning you ebrake should be fine.
why dont you just call or email stoptech and ask? you could probably get a faster response than posting here and hoping someone with your exact setup happens to click into this section of the forum.
My setup retained the parking brake. Per Neo, you can't get this kit new and there were only 3-4 max ever shipped. But as Teelex mentioned, it's all in the hat - regardless of rotor/caliper/kit related stuff we know stop tech has or had the proper hat for the rear brakes.
jeffandi
Suspension and Brakes
12-05-02 11:26 PM
