Hard to remove gas cap
Our 2001 RX has the hardest to remove gas cap. My wife can't do it at all!
Her sister has the exact same year RX and it's fine! I even bought a new cap
and it's just as difficult to remove as the OE cap
Also try removing the cap after a while [one or two days sitting in the garage]. The system is not totally air-tight. As fuel is used the tank does get air in. The monitor for leaks (slow evap leak) is calibrated for this.
Sali
How about swapping the gas-caps from your wife's to her sister's. If the problem does not travel then look at the filler-neck.
Sali
Sali
