View Full Version : Suspension and Brakes
- Missing parts from front shocks
- need yr opinion on this setup..
- axle boot.
- Getting a good stance
- Front wheel gap?
- For those with 18's + lowerering springs
- Clunk, clunk, clunk ...
- Here's one for you guys: THUD heard when reversing while turning the steering wheel.
- koni yellow vs tokico illuminas?
- SubFrame Mounts for TT Swaybars
- Supra TT brake question (powdercoating)
- Best price for Supra LCA's
- Advice on offset/suspension
- brake problem
- tokico shocks with espelir springs?
- PICS!!! daizen sways installed!!!!!
- Front disc brake on rear?
- Eibach NA Supra Springs work on Sc3?
- Brake Pads and brake lines
- Rough / loud braking w/ new slotted rotors?
- sc300 steering wheel shakes/jerks
- suspension difference?
- Tein Springs..??
- Steering whine/judder, please help!
- Used LCA's
- Serious Camber Problems
- GS suspension in a SC possible?
- tt sway bars?
- bigger brakes with 20's
- Espiller Springs
- swaybars, which one to go with??
- Supra LCAs and Camber question
- Supra lca's on SC400
- supra strut fit sc300?
- tein springs.....??
- Pretty wierd sounds coming from left back wheel (i think)
- SC 300 suspension
- vibration, and a wobble....
- FS: Fully Adjustable Racing Upper Control Arms
- Help me pick my suspension
- New Member. New Car. New Problems ;)
- Tilted wheels? Help
- price of suspension work on SC
- calling out cars wit tokico illuminas package
- 95+ LS400 Brakes
- Where can I get a good deal on Cannovers?
- OZ Saturn 18x8.5 and 18x10
- for those w/ teins or lowered cars...camber kit questions
- Tein Instructions in Engrish?
- HELP Which Brake pads to get?
- JIC or Cusco STB on a 1998-2000 SC400
- Scraped off 3 pounds of dirt!
- Partial TT Brake parts have arrived....but
- how bad is this going to be on my...
- Brembo Kit fitment
- Suspension recommendations anyone?
- Wheel bearing issues.
- finally dropped it
- lowering with eibach
- Tokicos with stock springs
- Can anyone diagnose this ?
- Is this a bad rack and pinion?
- alignment specs with supra TT wheels?
- Supra tt front brake upgrade with pics
- Intrax and tokico? Has Anyone tried this?
- sc300 offset questions on 18's
- Alignments after mods ?
- labor quote for changing front control arms
- For those with front AND rear supra brakes?
- Stock Springs
- rubbing
- daizen bushing kit for 92 sc300
- how much to drop
- Just finished replacing struts (problem)
- lowering sc300 and brakes
- For the love of SC300s
- please post photos of sc on twentys either with a drop or without
- Tein FLEX and Daizen Sways 2-week impressions
- Advice on supra tt front rotors
- 20" 265/35/20 all 4 with 1.25-5" drop will it rub!!
- What color should I paint my brake calipers?
- Supra LCA $ ?
- Bradi brake rotors and Axxis pads
- 20" Wheels - How low can I go
- control arm bushing swap
- Ball joints
- Strut installation time
- Bushings DIY ??
- Rotora BBK for GS's fit SC's?
- control arm question (again) - PLEASE HELP!
- TRD Supra Sway Bars
- Lowering and bushings
- free tokico shocks!!!
- Espelir Springs
- supra front control arms and stuff
- Can I use this ? (Tokico shocks)
- Stock ride height ???
- tein cs problems?
- how do Bilstein shocks hold up. *
- NEED Help ASAP on Daizen Bushings AGAIN!
- Need opinion on these rotors
- rear suspension squeaks
- What is the quality of this front strut bar for $40?
- Anyone know the part number for the steering rack bushings?
- Hey guys, look what came in five minutes ago..
- So whats the deal with rear control arms?
- NEED Help ASAP on Daizen Bushings!
- Daizen Bushings Front Instructions??
- HELP - Ball Joint Pop Off the Lower Control Arm
- noise at low speeds
- question on upper and lower arms
- Parts needed SHOCK BOOTS
- Satisfaction Level of your lowered SC 300/400?
- Supra TT brake questions
- Anyone got any hook ups from eibach?
- Pick me a Coilover Setup
- What suspension setup is best?
- Help me out guys with supra tt suspension.
- Supra TT Upper mounts the same as sc3?
- Struts needed---
- Will supra TT suspension / brakes fit?
- Anyone ever buy these bushings?
- SC300/400 Daizen Sway Bars available!!! =)
- How to slam the SC
- Weird wobbles on freeway
- Factory Adjustable Cambers?
- Where to go for Tokico Struts Install?
- Rack and Pinion
- What exactly from the supra will fit on the SC?
- Daizen Bushings and Ball joint Boots
- eibach pro kit question camber question.
- I Need Suspension Advice Please
- NEW TEIN FLEX CO's are in!!!
- Help me decide which SUSPENSION... Experiences needed.
- oem suspension life
- Tramlining
- Knocking and loose change
- dropped
- Big Brakes
- Rear Control Arms
- Eibach spring Help needed
- Swoosh sound!
- front brakes in the back?? is it possible?
- Daizen Sways?
- Anybody got camber kits from TM Engineering??
- Calling all Tein HA SC owners out there!
- tein cs coilover question
- Tokico Illumina setup - Issues
- Ugh. I'm an idiot.Help.
- Cross-drilled and slotted rotors (On Ebay)
- So, what did you get for Christmas? Woot! I finally got my coilovers!
- Got Springs?
- I want to LOWER my SC300
- good coilover setup
- Modify SC300 Steering Column?
- Supra brake clicking
- Hard Bumpy Ride (What gives)
- TT Brakes: It Was Worth It!
- hub mystery... and how to change wheel hubs?
- weather stipping leak
- what about the trd stb
- AGX struts & Eibach Springs
- what is that clanking noise when going over bumps??
- need suspension help quick
- bushing clarification
- Jic Flt-a2
- new suspension mods are in... (pix)
- supra turbo front strut bar?
- springs 92-99
- stoptech
- Camber adjustments
- need help fast!!!!!!!!!:( DAIZEN BUSHINGS
- Braking Options
- Manufacture of original '94 SC300 brake pads? Nippon?
- Noise from manual tranny; need advice
- Steering ? Braking Problem
- Lowest SC?
- Same steering rack?
- Supra lower a-arms
- squeaking sounds.?
- I love the Daizen Bushings!!
- extended wheel studs
- HP Racing Brakes....................
- Question for folks running TT wheels and brakes...
- Supra Bilsteins work great!
- Bleeding brakes
- Spring ?'s
- 92 SC400 Transmission Mount
- 20"s how big of a gap
- I have been Illimunated!!!
- Tein VS. ebach and tokico
- Lower Control Arms HELP!!!!!!!
- JIC Coilover Help
- DIY Daizen bushing install? I did it... Yikes!
- Is a seized caliper the culprit?
- where Is That Shock Install Diagram?
- Cold spell, odd noise from suspension
- What color did you guys paint your calipers?
- KYB's VS. Tokico's
- HKS Hiper Damper I for SC300
- anyone got a pic of some eibachs prokit on their ride?
- brake problem..
- handling mods
- Just installed Daizen Camber Kit
- I want my car to sit like this
- Tein Flex, CS, HA
- weird sounds from pass side
- 97-00 SC Front Control Arm Bushings
- Tokico Shock Questions
- who , what the best bushing kit 4 my sc300
- lsd
- lookings full coilover suspension /camber arms
- Lower Control Arm Bush Install Results
- Who carries front lowering springs.
- JIC SF-1 Coilover discontinued?
- ball joint failure
- Strut Bar & Rear
- broken grease boots
- HELP!!! Car Tilts to One Side About an Inch
- Front/Rear SC camber kit...YAY!!
- sway bar end link replacement
- Annoying creak coming from the back of the car.
- Serious Steering Wheel Shake (suddenly)
- How can i tell if i need new struts?
- Daizen front lower control arm fore/aft Bushings for 1997 Supra TT?\
- Daizen Anti-Roll Bar Bushings
- car height
- How high is your SC?
- Just a Thought....
- spacers for tt brake upgrade inquiry
- sc400 springs and shocks on sc300
- Front end Vibration need suggestions
- TT brake upgrade
- question bout coilovers
- Lower Arm Bushings?
- suggestions on springs/shocks?
- control arm bushings?
- JIC FLT-A2 and JIC SF-1 Coilover Pics!!
- drag coilovers?
- Problem with New Power Steering
- Camber correction?
- Clunking Noise in Suspension
- Supra TT brake upgrade F&R, install pics on project Silver Bullet
- JZA80 Suspension for SC
- a-arms from Supra fit SC 300?
- Just installed Sway & Ctrl.Arm Bushings!
- What kind of rotors are good?
- Im looking for a certain strut bar
- JIC Magic FLT-A2 ride quality
- Dropped front, should i do the rear?
